Old 01-23-2013, 12:01 PM   #1
Iggy's Avatar
Need help while on the road! 2012 378TS
It seems as if my black water tank spray cleaner line is clogged with something. I think it is the small while back flow valve that broke loose and is now at the spray nozzle at the black water tank.
I want to find the location of the nozzle that is at the balck water tank to remove and cleanout.
I'm unable to find or see where it is located in the tank at all. I look at the outside but can't get access to see where it is going or enter the balck water tank.
I'm looking for any information on it location within the Georgetown that I can take it out and clean it.
I will drop back here in the next day to see if anyone can help.
Maybe if you have a good technical contact at Forest River that knows Georgetowns will help.
Iggy
Iggy is online now   Reply With Quote
Old 01-23-2013, 01:54 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I know mine are on the opposite end of the tank from the place where you hook your hose. It crosses the coach then makes a 180 with a vinyl hose and attaches to the piece attached to the tank. I have 2 Black Tank with the bath & a half. 1 is easy to access but the other was behind the panel where the water heater is. I saw it when I replaced the support under the water heater.
http://www.forestriverforums.com/for...tml#post265925
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 01-26-2013, 05:46 PM   #3
Iggy's Avatar
We found the problem. It was a faulty back flow valve that was located inside the cabinet where the washer dryer goes.. Next Camping World I will replace.
Iggy
Old 01-27-2013, 12:15 PM   #4
Iggy's Avatar
Iggy
UPDATE.
Afrer a little playing with the backflow valve locate dinthe closet with washer and dryer I got it to work but still wasn't getting any water inthe tank. I decided to check the hot water tank area and opened up the compartment and found a wad of paper that was lodged in at the jet going into the tank. Removed the paper and all is well.
Someone at the Forest River factory was unhappy that day.
All is working well now. Yah!
Old 01-27-2013, 12:26 PM   #5
DnD
DnD's Avatar
Glad to see you got it all fixed Iggy!
Stay safe and enjoy the rest of your road trip!
Dan
PS I am still working on ideas for a west coast rally. Will PM soon.
Dan n Dione
TV: 2012 Ram 3500 Laramie CC LB 4x4 DRW
RV: 2013 Crusader 325RES Touring Edition
Days Camped: 2012 (3) 2013 (22)
Next Trip: Mission Bay, CA 6/6 - 6/9
DnD is offline   Reply With Quote
Old 01-27-2013, 01:21 PM   #6
bubbles's Avatar
What panel did you open to gain access to the spray nozzle where it enters the black tank. I have a 2012 378ts and was able to blow my clog out at the backflow valve output side but had no idea where to get at the spray nozzle. I would like to get at it to remove and slightly enlarge the spray holes.
378ts
