Old 07-02-2016, 08:54 PM   #11
borba's Avatar
try to load pics don't now y not working the dirt that was clogging the valve looks like saw dust [attach][attach]Click image for larger version
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 07-05-2016, 06:18 AM   #12
It is not saw dust. It is particles from your anode rod in your hot water heater. Been down this road tooooo many times.
Paul S. is offline   Reply With Quote
Old 07-05-2016, 06:52 AM   #13
KyDan's Avatar
I'm pretty sure my toilet is not fed from the water heater!
The OP doesn't say age of trailer. If it's new the "saw dust" might be plastic
shavings from when they hole sawed the fill hole in the fresh water tank. Or it might actually be saw dust from cutting faucet mounting holes or pass thru holes in walls while open plumbing lines are laying around.
Anyway it sounds like a happy ending for Frank!
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-05-2016, 07:12 AM   #14
Ford Idaho's Avatar
Originally Posted by borba View Post
try to load pics don't now y not working the dirt that was clogging the valve looks like saw dust [attach][attach]Attachment 112880
Attachment 112881[/attach][/attach]
Is the toilet the only water user that get clogged like that?
Outside shower, bathroom faucet?
Old 07-05-2016, 07:55 AM   #15
kenandterry's Avatar
You should check the filter screens attached to the faucet heads (kitchen, bathroom) from time to time. A little CLR can clean them for better water flow.
Water filters don't catch everything.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-05-2016, 10:44 AM   #16
Happy Trails!
Actually your toilet is fed through the hot water heater. My theory is that when your water system is fully under pressure and you flush the toilet the drop in pressure is not fully compensated for from your outside water supply source. Given that there is 10 gallons of water sitting at a higher pressure in your hot water tank the heater back feeds into your cold water supply line carrying any sediment or debris from the decaying anode. This sediment will pulse along each time the toilet is flushed until it gets caught in the screen of the flush valve. Also, the flush valve and the heater are roughly in the same horizontal plane compared to the sinks and the shower. This is why these tend to not get as much sediment as the flush valve. Hope this clears things up.
Old 07-05-2016, 03:18 PM   #17
borba's Avatar
did not now that a few more things to check we learning thanks
frank
2013-ford fx4
2009-harley flhx
water
