Old 07-01-2016, 06:33 PM   #1
borba's Avatar
need little help. no water in toilet
hi everyone need help all of the son no water on toilet have water every were pressure good but not there I am camping here for a week any help will be very much appreciated thank you
frank
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 07-01-2016, 06:38 PM   #2
Flybob's Avatar
Most likely crud in the valve. Turn of the water, release any pressure in the lines and remove the toilet valve. Clean out using reverse water pressure or compressed air if you have it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-01-2016, 09:08 PM   #3
Sbryant's Avatar
That was the trouble I had, and that's the way I cleaned it v
Sbryant is offline   Reply With Quote
Old 07-01-2016, 10:52 PM   #4
buddyu's Avatar
X 2
buddyu is offline   Reply With Quote
Old 07-02-2016, 08:43 AM   #5
borba's Avatar
thank you gone to try that this morning
2013-ford fx4
2009-harley flhx
Old 07-02-2016, 12:22 PM   #6
borba's Avatar
yes problem fix valve was full of dirt you guys rock on this forum thank you so much
2013-ford fx4
2009-harley flhx
Old 07-02-2016, 12:44 PM   #7
Lexi2007's Avatar
We encountered the problem but no matter what we did as far as draining the water, as soon as I loosened the water valve, it started spraying all over. Our temporary solution involved keeping a bucket in the shower between our feet and catching the clean soapy water. Then, when the commode needed flushing, we held the pedal down and poured a fair amount of the water down the commode. I spray cleaned every day and the fix lasted us 10 days. Jus' sayin'
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 07-02-2016, 01:19 PM   #8
bubbles's Avatar
You didn't fix anything. You had a work around. You have to turn off the water source and open a cold water faucet to relieve pressure then remove the toilet connection to clean out the clog in the toilet valve. Jus' sayin'.
Old 07-02-2016, 08:23 PM   #9
borba's Avatar
Bubbles I did exacle that close water release pressure take the valve out clean the clog
2013-ford fx4
2009-harley flhx
Old 07-02-2016, 08:32 PM   #10
buddyu's Avatar
Be sure to drain and flush your hot water tank and replace the anode rod plus get a filter to put at the water connection. All this helped.
water
