Old 03-15-2018, 09:04 AM   #21
Originally Posted by kyinger View Post
We just had our Georgetown GT5 31L5 and Jeep Cherokee set up with the Roadmaster All Terrain, DUO Stay and Play braking system, and the brake wiring kit. Planning our first major trip towing the Jeep in May from FL to PA and back.
I have the same system you have and love it. It literally takes less than 2 minutes to hook it up or take it down and no bulky braking mechanism. Though I am not knocking any system.
Love my setup.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 03-17-2018, 10:04 PM   #22
Hi tow bar recommendations- iam looking for a used dinghy setup complete... I have 2017 Georgetown 30X3 . Thanks
1964chevelle is offline   Reply With Quote
Old 03-20-2018, 05:43 PM   #23
John.Debbie's Avatar
I purchased a Roadmaster tow bar and base plate for my 2011 Jeep Wrangled. The braking system is a Stay in Play unit that mounts under the engine hood by the battery. When you use it all you need to do is hook up your toe bar and plug it in to the RV. Once you are hooked up just flip a switch mounted on the drivers side floor board and you are good to Go. The brake system is wired to the lights separately and automatically ChargeMaster in play unit your vehicle battery so there is no need to start the engine to recharge the battery. Very good unit and no need to mount a braking arm on the floor to apply the brakes. The stay in play unit will automatically pump your toad brakes when you apply the RV brakes. Bought it from a RV dealer and had them install it. Very satisfied.
John.Debbie is offline   Reply With Quote
