Old 03-09-2016, 05:55 PM   #11
The charge wizard is great, it will maximize the value of generator time. HOWEVER, it will not equalize since the "boost" voltage is only 14.5. Great for charging, too low for equalizing.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-10-2016, 02:37 AM   #12
x2
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 03-11-2016, 10:59 PM   #13
does the charge wizard switch between these modes automatically?
AbdRahim is offline   Reply With Quote
Old 03-12-2016, 12:11 AM   #14
TURBS's Avatar
Yes, or you can manually do it.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-12-2016, 07:20 AM   #15
Yes. The Charge Wizard automatically switches modes. The Charge Wizard is an optional external pendant on the 9100 series converters, and is included (built in) to the 9200 series converters. More detail here: Charge Wizard RV Battery Charging
Old 03-12-2016, 10:33 AM   #16
That is correct. However, on the 9200 series you cannot tell what mode the unit is in or manually override it (like forcing it to boost when boondocking and running the generator) without the $12 accessory pendant. The converter is doing it's thing anyway and switching modes without the pendant.
2015 335DS
battery
