Old 03-08-2016, 04:16 PM   #1
360true's Avatar
Need to equalize batteries?
My neighbor here at the park "equalizes" his chassis batteries twice per year and swears that his batteries require it for long life.
As I understand it, his charger runs up to 14 volts for 8 hours and this boils off any corrosion on the inner plates.
Truth or fiction? Do I have a way to do this built into my coach?
BTW. I have a 378ts with for 12 volt coach batteries.
360true is offline   Reply With Quote
Old 03-08-2016, 05:36 PM   #2
No, that is not enough voltage. Equalization voltage is at least 15 volts. Disconnect everything, remove caps and soak it at 15 or 15.5 volts for 3 to 4 hours.
I know of no converter that can do this. They talk about it, but there isn't enough voltage to do it.
Lead acid batteries only. Debatable if you need it. Trojan says only when needed. Needed when the specific gravity of the cells differs.
ScottBrownstein is online now   Reply With Quote
Old 03-08-2016, 06:26 PM   #3
Cyber Phrenologist
Radio's Avatar
And make sure the compartment is WELL vented!
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 03-08-2016, 08:38 PM   #4
360true's Avatar
OK but what is the advantage of the procesd and why do some coaches have an equalizer built in, and some don't? Do GT XLs have the capability?
Old 03-08-2016, 09:00 PM   #5
Trojan does not recommend equalizing batteries on a specific schedule. The very term "equalizing" means that the charge and chemical composition of the cells is different within a battery. If the specific gravity is something like +/- .015, then you hit all the cells with what amounts to a significant overcharge, allowing the cells to all become fully charged. OF course, the cells are in parallel and when you need to bring a given cell up, you are in fact overcharging the other cells. Equalizing boils a lot of electrolyte and you need a voltage of something like 15.5 volts for a 12 volt lead acid battery. Remember that boost charge from a converter is 14.5 volts. If successful, the specific gravity of all cells, and their state of charge will become equalized after a period of a number of hours. They recommend measuring specific gravity every hour until equalization is achieved.
Of course, equalization helps dissolve sulfate crystals and the boiling will help mix the electrolyte...but boost charging does the same. Personally, I think it is something that we all talk about but few actually do it, but they think that their converter or charger does it. Imagine boiling electrolyte with all of your electronics still connected...and you don't know it.
2015 335DS
Old 03-09-2016, 08:19 AM   #6
abjb's Avatar
360true ask your neighbor if you can borrow his Hydrometer.
Robot Check
Check YouTube, lots of "equalize RV batteries"
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 03-09-2016, 11:10 AM   #7
Iggy's Avatar
360true
I have a Progressive Dynamic Battery charger that came with my Georgetown.
IT does have battery equalizer build in but I also have a little button that changes it manually also.
Details
Converter Status Remote Pendant
The Converter Status Remote Pendant PD92201 is designed to plug into the standard accessory port on all models of the Inteli-Power 9200 Series Converters. The Converter Status Remote Pendant shows the charger/converter operating mode and allows for manual mode selection.
Note...
The PD92201 Converter Status Remote Pendant is available for purchase if you don't have one. Click here to Purchase
How it Works
The new PD9200 Series RV Converter/Chargers have our patented Charge Wizard built-in to provide you with the most advanced RV battery charging system on the market today. The Charge Wizard is a micro-processor controller that constantly monitors your RV battery voltage and then automatically determines which one of four modes of operation is best suited to recharge or maintain optimum battery condition. The four modes are BOOST, NORMAL, STORAGE and DESULFATION. The Converter Status Remote Pendant will show you which mode the converter is operating in.
The Indicator Light on the Converter Status Remote Pendant will display the mode of operation as follows:
  • Light “ON” all of the time – Indicates the unit is in the BOOST MODE and the converter output voltage is 14.4-volts and is in the process of recharging the battery up to 90% of full charge as fast as possible. This mode is usually automatically selected after dry camping
  • Light Blinks Rapidly (from once to many times a second) – Indicates the unit is in the NORMAL MODE and the converter output voltage is 13.6-volts. In this mode, the converter is safely completing the charge of the RV battery.
  • Light Blinks Slowly (every 6-8 seconds) – Indicates the unit is in the Storage Mode and the converter output voltage has been lowered to 13.2-volts. In this mode the RV battery is fully charged and the converter is maintaining the charge, without causing gassing or water loss.
The Manual Switch...
The Manual Switch allows the operator to check to see if the Charge Wizard is operating properly as follows:
Press and hold the Manual Switch and shortly the Indicator Light will remain “ON” all of the time, indicating the unit went into the BOOST MODE. Continue to hold the switch and shortly the Indicator Light will start blinking rapidly (every 2-3 seconds). This indicates the unit went into the NORMAL MODE. Continue to hold the switch and the unit will go into the STORAGE MODE, and the Indicator Light will start blinking slowly (every 6-8 seconds). Once the switch button is released, the Charge Wizard will again read the RV battery voltage, and after some period of time, automatically select the proper mode of operation.
The Desulfation Mode
The DESULFATION MODE is only active when the Charge Wizard is in the STORAGE MODE. During this mode a timer in the micro-processor automatically switches the Charge Wizard to the BOOST MODE for 15-minutes every 21-hours. This higher voltage causes some slight gassing, and mixes up the battery electrolyte to prevent battery stratification, and the resulting sulfation of the plates, which is the leading cause of loss of battery power.
Note: When no 120 VAC power is applied to the RV through the Shore Power Cord, or Generator, the Indicator Light will remain "ON" at all times. This indicates that the Charge Wizard is monitoring the battery voltage.
Here is a link if you want to buy this little button as a add on for $10.13.
Inteli-power 9200 RV Converter Remote Pendant - $10.13
Name:	Trailer Pics 010.jpg
Old 03-09-2016, 11:21 AM   #8
360true's Avatar
Iggy and others. Thanks for all this info. Really the best way to get an education about my coach!
Old 03-09-2016, 11:55 AM   #9
Iggy's Avatar
That's what we are all here to do is help, learn and
Old 03-09-2016, 12:27 PM   #10
X2. Some standalone battery chargers (Xantrex for one) can perform a desulfation cycle on FLA (maybe other types too) batteries. FLA = Flooded Lead Acid. One caution ... before performing a desulfation cycle, disconnect the battery (battery bank) from the load (that would be the MH or camper). A number of appliances in the load can not tolerate 15+ volts without damage.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
battery
