Old 06-29-2014, 07:27 AM   #1
Full Time RV'rs.
Nepas's Avatar
New 2014 GT 378xl Generator Probs
Hi all
We have a 5500w generator on our 2014 GT 378XL. I have been running the generator 5 hours a week. This past week in wont start, all the switch does is flash 1 time, no start. I even wait for an hour and re try still nothing.
We have moved to Rainbow springs state park, FL as campground hosts for 3 months and i tried again yesterday and 1 flash and nothing.
Is there something i'm missing?
TYAIA
Nepas is offline   Reply With Quote
Old 06-29-2014, 08:30 AM   #2
Have tried starting the gen from the starter on the gen?
jeffv003 is offline   Reply With Quote
Old 06-29-2014, 08:52 AM   #3
VinceU's Avatar
Originally Posted by Nepas View Post
Hi all
TYAIA
Check the Onan book for how to read the flash codes on the start button.
Old 06-29-2014, 08:59 AM   #4
LittlePM's Avatar
Check to see that you have more then a 1/4 of gas, other wise it won't work
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 06-29-2014, 10:36 AM   #5
Full Time RV'rs.
Nepas's Avatar
Full tank of gas.
If im reading the book right 1 blink is shut down due to high temp?
I am hooked to the park pole w/surge.
Also what is this. Something we didnt have on our 335 and the walk thru guy never showed us what it does.
The green light is not on.
Old 06-29-2014, 11:02 AM   #6
VinceU's Avatar
Full tank of gas.
Is the light and switch a small inverter? Changing battery power to 115 when shore power or gen not in use? Do you have a res refrig? If one flash is high temp you may have bad sensor, would guess its a limit against starting, like low oil pressure is, keep reading the book, maybe narrow it down.
Old 06-29-2014, 11:06 AM   #7
You have a 2014. It's a warranty problem and you should have a dealer fix it.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 06-29-2014, 11:59 AM   #8
Full Time RV'rs.
Nepas's Avatar
Yes we have a residential 3 door fridge. Not found anything else about about why not starting.
Calling mobile warranty tomorrow for it as this is our full time house, not staying at a dealer.
Old 06-29-2014, 12:18 PM   #9
VinceU's Avatar
Good move on that. Now you know to kick on this power supply for the fridge whenever you are not on shore power or running the gen set.
Old 06-29-2014, 01:51 PM   #10
Is the engine turning over at all?
The switch in the photo is to power on your inverter. It uses your house batteries to power your refrigerator. I leave ours on all of the time since it has an automatic transfer switch that will disconnect the batteries if it senses shore or genset power.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
2014, 378xl, generator
