Old 08-12-2015, 04:27 PM   #1
2016 Georgetown XL 360 DS
New 2016 Georgetown 360DS ready for pickup
Dealer just called, new motorhome is in!
Its been 10 weeks since we ordered it, I was starting to worry it would never arrive.
But I did spend those 10 weeks reading over a lot of the posts in this forum.
Thanks for all the helpful information guys!
I'll update how the PDI goes.
jimpacker is offline   Reply With Quote
Old 08-12-2015, 07:26 PM   #2
BillMFl's Avatar
I have a 2012 360 and really like it except for problems with the roof. I should have climbed up and checked it before taking delivery. There were sizable gaps at the rear cap corners. Wrinkles and small cracks along the driver side roof line. And eventually water leaks above the kitchen cabinets. Lots of other folks have had roof problems. Hope they have improved roof quality in the newer coaches. Do yourself a favor and check it at the dealership.
BillMFl is offline   Reply With Quote
Old 08-13-2015, 05:15 AM   #3
cjd10's Avatar
Congratulations on the new coach! Take your time during the pdi. Its difficult to do with all the excitement. Don't let them just point at things and tell you what they are for, make them turn them on and off including all the TVs and sound system including tuning in channels. Lots of little things can easily be missed like a faucet not working or a burner on the stove.
Also, an empty coach usually handles like crap. Much better after you load your "stuff"
and get a front end alignment. (FR will pay for this in the first 90 days) Consider doing the CHF for better sway control, and last but not least make sure your dealer has the correct air pressure in the tires. I left the dealer with 68 to 70 PSI in my tires.
Even after you leave you will still find things. Don't get discouraged, just keep a list.
Enjoy!
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is online now   Reply With Quote
Old 08-13-2015, 07:29 AM   #4
xman123's Avatar
I agree with CJD get the dealer to insure correct tire pressure mine was off also. and as he said check radios and tune in stations my outside AM radio doesnt work.
i also agree with getting a front end alignment mine was way off also and in fact im fighting a dog tracking issue right now with ford
Good Luck with your new toy...thats the model i almost went with but got hesitant and bought the one i have
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 08-13-2015, 07:40 AM   #5
xman123's Avatar
i forgot to add..FR is reimbursing me for the front end alignment
OK question Time...
Lancaster NY
Old 08-13-2015, 11:42 AM   #6
I had a 2012. Something that the dealer may not tell you. Get the front end aligned ASAP. Usually FR will pay for it if you do it when it is new. If you don't your front tires will really wear much to fast.
norwood12800 is offline   Reply With Quote
Old 08-13-2015, 08:11 PM   #7
Vince and Charlette's Avatar
I had the CHF done and it started "clunking" on my 2015 Georgetown. FR sent me to an alignment shop where I was told that I was the third Georgetown owner this year where they had to undo the CHF as it causes the tip of anti-sway bar to travel too far and contact the underside of the frame.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 08-13-2015, 10:48 PM   #8
GABoy's Avatar
Must be specific to your model. I've never had a clunking noise. CHF been done for last 5000 miles on my 2014 351.
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 08-14-2015, 04:51 AM   #9
cjd10's Avatar
Never had it on mine either. Again, maybe a model issue. Might also be cause I carry so much weight in that huge rear compartment in helps keep the nose from dropping down and hitting those sway bars. But then again I've never had it happen when unloaded either.
Charleston SC
georgetown
