Old 03-06-2011, 02:11 PM   #1
New 360DS Owner with Questions
Thanks to everyone here our pick-up and demo went well. Once we got the campground set-up went well. I do have a couple of questions though. Our coach is equipped with dual a/c the front a/c set at 70 would cycle normally. However the rear a/c set at 76 ran constantly until I just turned it off this morning. The air temp blowing out of the rear a/c was cool. Is this normal? Also all the basement locks required a lot of silicone spray and manipulation to get them to operate correctly. The dealer told me this is normal for those locks. Other then those two minor issues our initial outing was a lot of fun for the family. We have a lot to learn but are looking forward to the adventure.
XXLGator is offline   Reply With Quote
Old 03-06-2011, 05:08 PM   #2
Hey my new 360 rv friend. I have a new 360 we have not used yet but we have had 12 mh's in the past. If the A/c wont shut off then you have defective thermostat...I am not sure on the basement locks...they should operate smoothly..but hey, Mine is still in storage intil spring...
polkatronron is offline   Reply With Quote
Old 03-23-2011, 10:02 PM   #3
Would the fan switch be on, or on auto?
I am sure you already looked at this, but my FR 375 has a fan switch, along with the Heat, Off, A/C switch. If your fan switch is in the on position, even if the A/C is not operating at the time, ie. temp below what you have set on the thermostat, the fan will continue to run. Just my thought. Like I said, you probably already thought of looking at this.
Have fun in your RV.
Ron
Rongrice is offline   Reply With Quote
Old 03-27-2011, 05:16 PM   #4
Since I don't have access to mine just yet,,,,still at the dealer, can the front tanks and the back tanks be dumped through the rear exit valve or do we have to dump from both outlets.
