Old 06-04-2016, 06:55 PM   #11
camaraderie's Avatar
Sounds fine to me given the new system and he number of batteries. The true test will be the next fill. I gotta get one of those systems...wonder if they'll be selling them at the Goshen show.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-06-2016, 10:40 AM   #12
Originally Posted by dphorton View Post
Which Battery Water System are you using. Looking to purchase on for myself.
Sorry about the late response, I was camping in the boonies where they don't even have cell service.
I bought the Pro-Fill from Flowrite. I chose it because it had one piece 3 cell valves. Easy to install and less risk of leaks.
I am posting a quick review right after this.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 06-06-2016, 10:41 AM   #13
Originally Posted by Dabmeb View Post
The battery watering systems I use allow a higher water level in the battery. When you figure in filling the lines and then having the water up to the auto stop you have added less than 250ml per battery and they may not have been topped right up when you picked up the unit.
Now that they are filled this is the time to start monitoring them.
That was my thinking, we will see how it goes month to month.
Thanks!
Old 06-06-2016, 04:02 PM   #14
I meant to say Qwik-Fill. I reviewed it here.
Old 06-06-2016, 04:54 PM   #15
Ned
Flavor infusor
I checked the water level in our 2014 351 this weekend and found all cells low. I used a flavor infuser that I had to add the water. No mess at all. You can find these in the kitchen gadget area at Walmart. Each battery took about 16 ozs.
Ned is offline   Reply With Quote
Old 06-11-2016, 02:54 PM   #16
Here is my auto fill system.
As you can se very little room on top.
Name:	ImageUploadedByForest River Forums1465674843.080221.jpg
Name:	ImageUploadedByForest River Forums1465674863.671571.jpg
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-11-2016, 03:50 PM   #17
Nice 6V setup!
Old 06-11-2016, 08:22 PM   #18
Thanks.
Except those are 2 12 volt batteries
There are 6 more cells under them hoses. The watering caps are only 1/4 " tall
2008 Honda CR-V
Old 06-11-2016, 08:58 PM   #19
Oops! Those cable cut it right in half!
Old 06-12-2016, 12:06 AM   #20
Senior Member - Retired
Wrapperman: Which battery watering system did you buy?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is online now   Reply With Quote
water, battery
