Old 03-18-2015, 01:24 AM   #1
New front speaker & wiring questions
Hi helpful friends!
We are planning on installing 2 front speakers above the passenger and driver seats and are thinking we should be able to run the wires behind or towards the back of the dash underneath, and run them up the front columns, which I believe come off.
Anyone have any experience with removing them? There seems to be an opening at the top at the back of th cabinet, so we are hoping our idea works...
I spent about 30 minutes searching and a few mentions were made, usually about the wiring for the front shade being back there but no specifics on removal. Maybe it's easier than I am thinking? Would prefer not to break them while trying to figure it out....!
The new 2015 have speakers installed exactly where we are thinking of putting them, but who knows where the wires are.....!
Thanks in advance
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 03-18-2015, 07:54 AM   #2
Kanadian Kamper
kenandterry's Avatar
The route for wiring changes between models and years. No one should assume that their scenario works for everyone.
That being said, I did run part of the wiring for my satellite radio antennae to the top of the front columns, and down the length you are describing. My wiring gauge was extremely small, so I didn't actually remove the plastic coverings, but rather just pressed my wiring in behind the edges of the trim. Then, again because my wiring gauge was so small, I ran it along the seam between the dash and sidewall and dropped down to finishing the route under the dash to the center console. I never really investigated in detail as to whether wiring from inside the column passes through the corner of the dash and underneath the dash to wherever. Remember, it is probably safe to say that there are wires for the overhead dash fans, and power blinds if your rig is so equipped, inside the columns so be careful not to damage them in your project.
Ken and Terry
kenandterry is online now   Reply With Quote
Old 03-18-2015, 09:28 AM   #3
GABoy's Avatar
Originally Posted by ChrisAndGarren View Post
Hi helpful friends!
Thanks in advance
Garren
Can you post a pic of the exact location you are thinking of mounting speakers? We have overhead bunk so wandered if it would interfere. I have thought about placing two 6.5" coaxials lower maybe like kick panel style. Still thinking though.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 03-18-2015, 10:49 AM   #4
The Wandering Irishman's Avatar
Here's a pic from a 2015 351DS. I also have the 2014 with the front bunk and was looking at this the other day. There is a shelf on each side of the bunk, directly in front of that you likely have a small square that is just wood, like it should be a cabinet but it's not. That is where Forest River put the new speakers.
In the new 2015's, these two front speakers are powered by the dash stereo unit. The surround sound speakers are powered by a new stereo unit placed over the entry door. There is some debate as to what the subwoofer is really attached to.
There was another thread, can't remember who the author was, had mentioned they replaced their dash unit with a model that had separate sound zones (like an A\B switch commonly found on a home stereo). They then added new speakers up front and were able to then alternate between the zones. Sounds like a nice setup to me!
Let us know what you come up with.
Tom
The Wandering Irishman is offline   Reply With Quote
Old 03-18-2015, 11:20 AM   #5
Sorry, the picture turned on me. Try again....
Old 03-18-2015, 01:06 PM   #6
Tom, that is exactly where we are looking......
Old 03-19-2015, 06:42 PM   #7
Any know anything about removing those panels in the windshield corners to feed wires through the channel?
wiring
