Old 02-05-2012, 04:13 PM   #1
New Georgetown Inspection List Part 1
Sooooo, forums say the inspection is all important so I've put together a list of things to inspect/test/understand based on the reading I've done in the forums.
Anyone have any addition suggestions?
APPLIANCE INSPECTION
Generator Operation/Maintenance
- How to start normally
- How to start if coach batteries too low
- How to check oil level
- How to change oil, oil filter, air filter
- Any other operations/maintenance tips
- Generator fuel consumption per hour, cut off to avoid draining tank?
AirCon Operations/Maintenance
- Check 4 mounting screws on each unit, know to be loose and allow water penetration
- How to operate from generator and from shore power
- Check all thermostats working
Furnace Operations/Maintenance
- Propane only?
- Average LP consumption volume per hour
- How to turn on
Fridge Operation/Maintenance
- Propane or 120 only?
- Operations/how to switch between supplies
- Check water/ice dispenser working
Stove/Oven
- Gas only?
- Operations
- Maintenance
Microwave Operation/Maintenance
- 120 only?
Hot Water Heater
- Operation/how to switch between supplies
- How to drain tank (drain and pressure relief valve)
- How to isolate/bypass tank
Fireplace
- 120 only?
- Operations
- Check to see if noisy when driving others have had dealer place gasket on glass seal to quiet
Air Mattress
- Blow up air mattress and leave to check for leaks
For all Propane appliances
- Understand how to light pilot, where to be able to see burner to check for operation and where vents are for each appliance to be able to maintain
Manuals
- Make sure manuals present for every appliance
WATER / SEWER INSPECTION
Drains
- Where is cold water supply low point drain valve
- Where is hot water supply low point drain valve
- Where is hot water heater drain valve and pressure relief valve
- Where is the fresh water tank drain valve
- Where is grey water tank drain valve
- Where is black water tank drain valve
- Where is water pump drain valve
Tanks
- FILL fresh/grey/black tanks and leave full to check for leaks
- Drain all tanks to understand process and check valves for leaks
- Understand where vents are for each tank
Water Pump
- How to drain / prime
Pressure Regulation
- Is there a stock supply pressure regulator
Water Filter
- Is there a filter,
- operations/maintenance
Chemicals
- Understand chemicals for black tank
Winterize/Storage
- Understand process
Run all taps, shower, toilet and look for leaks
Inspect all undercounter plumbing supply/drain fittings
Fill/drain sinks to check venting
Check shower water pressure
ELECTRICAL
Electrical
- Understand where all fuses/breakers are
- Understand which breakers in panel supplied by which of the L1 L2 lines in the 50amp service
- Understand if the 20/30 to 50 amp plug adapters energize both lines in panel
- Where are any fuses that are not in panel, understand fridge and others may have in-line fuses close to appliances
- Make sure have spare fuses for everything
- Make sure have spare bulbs for everything
- Understand there was an issue with levels and heated mirrors sharing a diode where if mirrors used when levelling could blow diode, fix is available, has it been done
- Understand what uses AC, what uses DC, what uses gas and what can only be used when generator/shore power on
- Understand type of converter, is it 3 stage charger or fixed trickle charge
- Is there a surge protector for over/under voltage, reverse polarity, open ground, single neutral
Batteries
- Understand battery monitoring equipment
- Isolation switch location
- Maintenance
Artic Pack
- Understand location of all arctic pack pads
- Understand fusing of all pads and any monitoring capability
- Understand if anything required other than pads for low temp operations
- Any times to use/not use pads (ie empty tank implications)
Use every light, switch and check each outlet for power
Run generator and check voltage on interior AC outlet
SinkorSwim is offline   Reply With Quote
Old 02-05-2012, 04:54 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
My recommendations: Take your time -don't let them try to rush you, take your list with you-there's tons of stuff to look at, ask questions about anything you don't understand. Your list is excellent but the excitement of getting a new coach can make you want to get on the road as fast as possible. Best wishes with your walk through.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
