Old 02-01-2015, 01:25 AM   #1
New Georgetown Owner
Just got home, took notes and guess what? I still can't figure out everything. Can anyone please tell me the steps i need to take to turn on the AC? I turned on the generator, set the thermostat to auto, set temp and no action. What am I doing wrong? Thanks! Please respond as if your talking to a 3rd grader...Step 1, step 2, step 3...
also, i have a Georgetown 351 DS
edmonh is offline   Reply With Quote
Old 02-01-2015, 07:26 AM   #2
Do you have a hard wired surge protector? If you do then it can take about 2 minutes before power is allowed to flow from your generator to the house depending on the model.
Watertown is offline   Reply With Quote
Old 02-01-2015, 08:15 AM   #3
Do you have to plug your power cord into a outlet in the generator compartment? Did the microwave have power? Did you check the circuit breaker?
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 02-01-2015, 09:50 AM   #4
tncruiser's Avatar
I cant help but welcome to Gtown as we enter our 4th year of ownership we are very pleased with FR they have cover a few defects beyond the warranty .we removed our sofa and dinette and went for table and 2 chairs and 2 recliners like get a new motorhome . go to the frog rallaye in august if you can a great time and experts to address any issues.
reasons I like my Gtown
it fits in my drive any longer and it would not fit and turn around on our dead end windy in the woods road
its paid for at my age I am too old for any debt
FR and BoatnRV have been great to deal with
and a great website of owner always willing to help
now go forth and RV
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 02-01-2015, 10:19 AM   #5
cjd10's Avatar
As others have said make sure you have AC power.
If your thermostat is set to auto the AC will not come on unless the temperature is set colder than the room temp.
Try setting the temperature colder using the arrow down button while the setting is on AC
Or set change the fan setting to hi or low
Press the selector button once to select the fan mode
Press the up or down arrow to select between hi low or Au
Press the select button once more to select AC.
The fan should run even if the AC compressor is not on.
It may take a few second for the fan to come on. That is normal
If you have AC power and the fan still does not come on check the breaker for the AC. The breaker box is under the bed facing you as you walk in the bedroom.
I had my breaker trip the first time I used the AC but haven't had any problems since
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 02-01-2015, 11:27 AM   #6
abjb's Avatar
1. Start generator
...Did it start?
...Did the microwave clock come on?
If yes to step 1
2. Check thermostat
...AC light on
...Temperature set lower than room temp
If yes to step 2
3. Check breakers
...1 or 2 should be marked in the breaker panel inside your 351
...There will also be breakers on the generator
4. Contact your dealer
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-01-2015, 03:19 PM   #7
Thanks everyone!
Old 02-01-2015, 04:21 PM   #8
chrisbailey13's Avatar
So, what was the issue?
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
Old 02-02-2015, 04:11 PM   #9
Chris, the 30 amp on/off switches on the generator were turned to off. I am glad it was something simple. Thanks for all the suggestions and quick replies.
Old 02-02-2015, 10:22 PM   #10
now go forth and RV
brianj
how hard was it to remove couch & dinette I have 2015 335 gtown I would like to do that thanks Bob
backwoodsbob is offline   Reply With Quote
georgetown
