Old 07-01-2014, 07:27 PM   #1
mack1roc's Avatar
New georgetown questions
Is the outside entertainment on the 14/15 georgetown a stand alone unit and if it is can you connect a iPod via Bluetooth or USB , or is it a remote to the inside stereo and I know that has a aux in. Second question might be stupid but I am sure you can hear the outside tv on those outside speakers right ? Also anyone know what size the outside tv is ? Last question is what size and how many furnaces does it have the brochure does not list it?
"MACK"
2006 F350 6.0 Diesel 3.73 4x4 FX4 "sold"
2010 Keystone Laredo 310RE 5th wheel "sold"
2015 Georgetown 351
mack1roc is offline   Reply With Quote
Old 07-01-2014, 08:48 PM   #2
chrisbailey13's Avatar
The outside entertainment is independent of the inside system with the exception of the antenna/cable connection to the TV. I believe the outside TV is a 32".
The TV does play through the outside speakers if you have the radio in Aux or if you are watching a DVD via the stereo.
The number of furnaces depends on which Georgetown you are asking about.
chrisbailey13 is offline   Reply With Quote
Old 07-01-2014, 08:54 PM   #3
mack1roc's Avatar
Thanks I found what unit it is and there is a USB on the back of it I am curious if there is access to the back of the unit under the kitchen cabinets. I ordered the 351ds and no clue how many and what amount btu furnace.
"MACK"
2015 Georgetown 351
Old 07-01-2014, 09:09 PM   #4
There is access to the TV under the kitchen counter. there may also be an USB connection on the side of the TV,
I believe the 351 only has one 35K BTU furnace.
Old 07-01-2014, 09:10 PM   #5
2015 351DSF Specifications
Sleeps 7
Slides 2
Length 35 ft 9 in
Ext Width 8 ft 5 in
Ext Height 12 ft 1 in
Hitch Weight 5000 lbs
Gross Weight 20500 lbs
Cargo Weight 4240 lbs
Fresh Water Capacity 50 gals
Grey Water Capacity 41 gals
Black Water Capacity 41 gals
Tire Size 245/70R19.5
Furnace BTU 35000 btu
georgetown
