Old 02-02-2013, 08:34 AM   #1
New GT XL 378TS
Set to take delivery next week of our new 378TS. Just found out it has an all electric fridge, powered by a dedicated 1000W inverter and 2 Exide 105AH batteries. I did get him to change the batteries to Interstate 31-AGM7s. Does anyone know the AH rating of said battery ? It has a published RC of 182 minutes. Can that be equated to AH capacity? Dealer yet has to divulge the make/model of new fridge, other then 22.5 CF. Anyone know?
Merry Groundhog Day
goodstick is offline   Reply With Quote
Old 02-02-2013, 08:55 AM   #2
Congrats on your new GT XL 378TS.
Old 02-04-2013, 06:46 AM   #3
Iggy's Avatar
Congrats on the 378TS!
So you have the 4 door refrigerator and it runs off batteries 100% of the time?
Mine runs on batteries while travelling and plugs into the standard 120 volt AC outlets when plugged into shore power.
You sure it is an invertor or is it the battery charger in the cargo bay with shore power?
Where is it located? A picture would be cool.
The batteries are 810 CCA each
Old 02-04-2013, 09:03 AM   #4
bend302's Avatar
Actually it should be a Samsung 22ft residential unit. I might be wrong on the brand but I saw them at the Tampa show.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 02-20-2013, 09:19 AM   #5
Congrats on your 378. Mine has a four door fridge that runs on electric when plugged in and propane while driving. It is a 2013. Good luck.
XL 378 is offline   Reply With Quote
Old 02-20-2013, 02:56 PM   #6
Which type refrigerator is the best to get? I do not plan on doing any boondocking, but may do a Walmart or rest area stop sometimes.
reubenray is offline   Reply With Quote
Old 02-20-2013, 09:17 PM   #7
Uncle AL
Merry Groundhog Day
Hello:
We are in the process of comleting the purchase of our 378XL and I find we have the same fridge. I am concerned about the battery longevity with the current inverter. What will the updated batteries do in terms of increasing the time you can run the fridge and anything else you may want to link to this inverter? Are you considering adding an additional battery or extra inverter?
Thanks,
Uncle Al
Uncle AL is offline   Reply With Quote
Old 02-21-2013, 08:40 PM   #8
VinceU's Avatar
The ref ridge doesn't use lots of energy to begin with. While the engine is running, everything the batteries provide will be made up by the alt. When in a park, the power is direct. If those two big batts can't hold for a night at Walmart, they're no good anyway. Many "A's" have 117 volt fridges.
Old 02-22-2013, 11:02 AM   #9
Send a message via Skype™ to Falcon35
I know if I was ordering our 378 now I would seriously consider the residential fridge.
I have had the Dometic fridge replaced when the coach was new. Since that have had Dometic fix the seal on the freezer door and a leak from the drain. Last week they replaced the fans. The water dispenser only works some of the time and the ice maker i not working.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
378ts, refrigerator, battery
« Safe? | Rock guard »
