Old 08-06-2015, 10:36 AM   #1
New owner help
Any way to get info on a 2010 Georgetown?? Seems the website only features new models , no archives!!
Dometic A/C unit went out and can't find the interior elec panel....
Help please............................
belsy is offline   Reply With Quote
Old 08-06-2015, 10:41 AM   #2
jlbreaux's Avatar
You tube is wonderful tool.
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 08-06-2015, 10:51 AM   #3
Weekender
Ford1's Avatar
Are you looking for the Fuse/circuit breaker panel?
Ford1 is offline   Reply With Quote
Old 08-06-2015, 11:09 AM   #4
breakers
Yes, interior fuse / breaker panel??
Old 08-06-2015, 11:23 AM   #5
Krazymace's Avatar
Mine is in the bedroom, under drawers.
Krazymace is offline   Reply With Quote
Old 08-06-2015, 12:01 PM   #6
Weekender
Ford1's Avatar
The breakers supply AC power to the compressor and fan motor. There may be a fuse for the 12VDC thermostat and control circuit. There is a control box/circuit board mounted inside the A/C unit that is accessible from inside the MH when the A/C Filter cover is removed. The 12VDC controls the operation of the relays that activate the compressor and fan. But before we go in to that level of detail......If the breaker does't solve your problem, give us some more symptoms that you are experiencing and maybe we can go from there.
Old 08-06-2015, 12:05 PM   #7
chrisbailey13's Avatar
Which model Georgetown is it? the Breaker is in different places based on the model.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
Old 08-06-2015, 12:16 PM   #8
It is next to the Bathroom on the 330TS & 350TS
Its under the forward closet in the MBR on the 378
Its under the bed on the 300FWS
and the 320DNS
Old 08-06-2015, 12:41 PM   #9
Breakers
Mine is a 2010 374 TS , I will re-do my search based on the new info !!
Thanks everyone
Old 08-07-2015, 11:43 AM   #10
Belsy,
Did you find it?
Old 08-08-2015, 08:52 AM   #11
Got lucky
The breaker panel was in the bedroom and the front air breaker had tripped.......re-set it and so far so good.
