Old 04-07-2013, 06:53 PM   #1
Newbie question about my 2013 352qs floor
Hi Guys I just recently bought and got delivery of a 2013 352qs. I just took it out this weekend for the first time. I have to say that everything worked pretty smooth and had no major issues. My only concern is that the floor in certain spots squeaks and warps when stepped on. Is the normal or something I should address while I still have the factory warranty? There is no bubbling or anything in the linoleum. Your help and input is greatly appreciated. Thanks again for your help.
Htab is offline   Reply With Quote
Old 04-08-2013, 06:34 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Congrats on the new Georgetown. We had a couple spots in the kitchen where the squeeks occurred. I found that the cabinets needed to be tightened against the floor inside the cabinets. Two screws and just a bit of a turn or two and the noise stopped. Not sure this is where your squeek is coming from but it gives you a starting point. Good luck and let us know what you find.
Oh you will need a Robertson head type screwdriver to tighten the screws. You'll need one anyway since that is the type screws that FR uses to put these RVs together.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 04-08-2013, 10:12 AM   #3
Cfsoistman thanks for the response. Most of the squeezing is coming from next to the cabinets. In the kitchen and the hallways. I will do what you said and get back to you guys. Thanks again for the help.
