Forest River Forums
Sunline User Photos
Old 10-04-2011, 04:59 PM   #1
Newbie trying to winterize
Have a 2011 Georgetown 320 DS. Finally found the drain for the hot water heater, but not sure I found the bypass . In the cabinet under the kitchen sink there is a panel marked "not for storage". After removing this panel I found the water pump and some water lines. There are three valves on the various lines. Are these the HW bypass valves? If so, do I turn all three 90 degrees to bypass the HW heater? For some reason, I thought there were only two bypass valves.
Wbreagy is offline   Reply With Quote
Old 10-04-2011, 05:03 PM   #2
Not for sure...you need to find the valves that are directly behind the water heater.
polkatronron is offline   Reply With Quote
Old 10-04-2011, 05:06 PM   #3
grhodes50's Avatar
3 valves are normal.
You should have one on a line going to the bottom of your water heater tank. This will be the cold water inlet.
Then there will be one on a line coming out towards the top of your water heater tank. This is the hot water outlet.
Then one valve on a line connecting the two lines. This is your bypass valve.
The valves are in the closed position when perpendicular to the water line and open when parallel.
To winterize, drain the hot water tank, close the cold inlet and hot outlet valves and open the bypass valve.
I hope this helps.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
Old 10-04-2011, 05:20 PM   #4
I hope this helps.
Thank you, Grhodes50. You described my configuration perfectly. I guess I'm in business. I've never seen an industry that gets away with so little documentation for such a complex product as a motorhome.
Old 10-04-2011, 06:54 PM   #5
grhodes50's Avatar
Most manuals are generic and offer very little detailed instructions.
That's why a thorough PDI is important, but i think I knew as much about the tt as the service tech on the last one I had. Most of my questions were answered with "I don't know" or "I'm not sure."
I eventually figured everything out and I'm quite comfortable with the tt now.
Gary & Trish
Close [X]
