Old 07-02-2016, 07:52 AM   #11
RSchleder's Avatar
Also, realize that DTV signals are very directional. Because of this fact, the antenna will need to be pointed toward the TV stations you are watching. Check out what direction your neighbors TV antenna's are pointing. Point yours in the same direction, do the process described above with the booster ON and you should see the number of channels being found during the scan. Don't interrupt the scan in process, it may take several minutes, just allow it to complete before you try watching or changing any TV channels.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-02-2016, 08:22 AM   #12
You could ask another rv'er by you for help. If you tell them you are new to rving you will be surprise on how much help you will get. Good luck
revflyer is offline   Reply With Quote
Old 07-02-2016, 01:00 PM   #13
mike.t's Avatar
Perform a cable scan? Think you mean channel scan.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-03-2016, 05:59 PM   #14
I have Samsung TV'S in the dining area and the bedroom. If I'm using the antenna, I need to go to Menu and tell the TV that I'm using the roof top antenna, "AIR", turn the boost on and do a channel scan.
If I'm getting the campground cable, I need to tell the TV I'm using "CABLE", make sure the boost is OFF, and do a cable channel scan to lock into channels available.
johng4706 is offline   Reply With Quote
Old 07-03-2016, 08:54 PM   #15
We have not gotten our TV to work yet either. Keeps going thru channel set up and no farther. Not been to a point t at we'd watch but would like to figure it out just in case.
Sujo70 is offline   Reply With Quote
newbie
