Old 07-02-2016, 05:12 AM   #1
kentdavido's Avatar
Newbie TV at RV Park
We're brand new and having a great time. So, last night we decide to watch Tv. The kids have been enjoying movies in their bunks in our new 2016 Georgetown 364ts. We could not get any antenna service or RV park cable. What are doing wrong. First we tried the antenna, hit the power button above the passenger's captain chair and slid the switch to antenna, saw good reception blue on the antenna, turned on tv nothing....set up on the Furrion Tv was on Tv,,,,nothing. Then I connect the cable to the RV park and then the rig, come in slide the box to cable, set a cable channel from the RV park, NOTHING. Went into set up and tried various components,,,,,,NOTHING........Help. We're Stupid,,,,but enjoying every minute of this great adventure.
kentdavido is offline   Reply With Quote
Old 07-02-2016, 05:58 AM   #2
Did you pay the Extra $ for cable? Some parks charge for cable! Youroo!!
Old 07-02-2016, 06:05 AM   #3
nomad297's Avatar
Did you change the signal source on the TV and do channel scans for the cable and over the air?
Bruce
nomad297 is online now   Reply With Quote
Old 07-02-2016, 07:14 AM   #4
kentdavido's Avatar
Bruce, what should the source be set on,,, we tried everything but actually assumed we were never on the correct channel to have received anything. Thank you
Old 07-02-2016, 07:21 AM   #5
Ford Idaho's Avatar
If you hooked the coax to the CG cable your tv must be set to cable as the source.
Old 07-02-2016, 07:27 AM   #6
kentdavido's Avatar
TV
There was Tv, AV, Component,,, HDMI 1, 2 and 3,,, and PC...thanks
Old 07-02-2016, 07:30 AM   #7
Also if you do finally get the cable channels turn the antenna booster off as it might make the picture have static.
dblr is offline   Reply With Quote
Old 07-02-2016, 07:35 AM   #8
bubbles's Avatar
On that menu select TV and then go into your menu (setup) and select source input to set what the input is (air or cable) and run the channel scan. Don't know what make of TV you have and do you not have an owners manual? There is no specific channel for these inputs the channels will be what ever they are, just like at home.
Old 07-02-2016, 07:41 AM   #9
nomad297's Avatar
This will do it.
Bruce
Old 07-02-2016, 07:49 AM   #10
clr
First every RV may be different but this should work for 90% of RV's that you have not added to or modified in some way. First the TV needs to be set to (input) from TV, that is the coax connection. For cable the booster must be off. Set the setup (software) of the TV to cable. Perform a cable scan. This should get you up and running on the campground cable.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is online now   Reply With Quote
newbie
