No 12v outlet
I have a question that is probably pretty simple, but I can't figure it out. My 12v outlet in the dash doesn't work. I checked the fuse in the engine compartment and it is good. Any ideas?
On a side note, I took the dash out to see if the 12v had come loose, or if there was an inline fuse that may have b!own. While I was in there I found out my unit has a satellite tuner that wasn't plugged into the head unit. The ends where taped together but not plugged into each other.
Quality at its best
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
