Old 09-24-2013, 01:32 PM   #1
Mature Citizen
downeyr's Avatar
No HD or DVD Picture on 378TS
I just picked up my new rig and there is no HD signal from the Dish receiver to the TV; just SD. The techs spent a couple of days getting the satellite and everything hooked up but still no HD. Getting behind the TV is a challenge and running another cable (HD) would also be a challenge. I am going to take it back to the dealer later in October to fix some other issues. Any ideas about the HD problem? Thanks.
downeyr is offline   Reply With Quote
Old 09-24-2013, 02:40 PM   #2
Iggy's Avatar
What year and model Georgeotwn do you have?
What dish did you buy?
What SAT company? DISH or DirecTV?
What package did you buy?
What receiver box model?
Did you change your viewing prefences in the SAT receivcer box to ALL channels?
Hopefully this will help you find your answer
Old 09-24-2013, 03:06 PM   #3
How do you know it's not HD? Because of the aspect ratio or because of what it says on the receiver info?
Old 09-30-2013, 09:49 AM   #4
ramair's Avatar
If you are running thru coax from receiver to TV then its SD, you need to run it thru an HDMI cable and the picture is great (HD). This is what I had to do, moved the receiver to the inside cabinet above the fireplace.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 09-30-2013, 10:04 AM   #5
bubbles's Avatar
I believe you will find, like my 378TS, that FR did not run an HDMI cable to the TV. Coax interconnect from SAT will not give you HD. The MH is prewired for SAT but that did not include HDMI cabling.
Old 09-30-2013, 06:39 PM   #6
Mature Citizen
downeyr's Avatar
Moving the satellite receiver
How do you move it into the cabinet with the television?
Darlene, Ralph and Pippin
LTC (USA Retired), W7TLD
2017 - 188 days & 7944 miles
2013 - 2016 - 432 days & 21429 miles
2013 Georgetown XL 378TS, 2014 Honda CRV
Old 09-30-2013, 07:49 PM   #7
I am not sure if this has been addressed but according to what I learned, after the fact, certain satellite systems are standard only; not capable of HD. We have a Winegard In Motion dish w/ Direct TV receiver and we can only get a standard signal.
Bgill is offline   Reply With Quote
Old 09-30-2013, 08:02 PM   #8
The OP said he's using Dish and they don't make it difficult to get HD like Direct does.
Old 09-30-2013, 08:28 PM   #9
Denver, CO
garbonz's Avatar
To be clear, you need HDMI cabling from the SAT RECIEVER to the TV and without that, no HD. Thou must do a mod to get that done. I love mods...
2017 Fuse 23T
Old 10-01-2013, 07:44 AM   #10
bubbles's Avatar
The OP may have a newer 378ts where the cabinet under the TV was eliminated. My 378ts is a 2012 and has a cabinet between the tv and fireplace but I have noticed that on newer models this cabinet has been eliminated. Routing an HDMI cable to TV from overhead receiver location could be a bucket of worms if it needs to be hidden. Good luck.
378ts, dvd
