Old 12-22-2014, 10:07 AM   #1
No headlight high beams
I do not have headlight high beams on my 2014 Georgetown 360 motorcoach. When I move the multi headlamp sw to what would be the high beam setting the headlights go dark. Where would the fuse be located? Any and all help will be greatly appreciated.
Thanks in advance for your assistance.
Ken Kaiser
kenkaiser is offline   Reply With Quote
Old 12-22-2014, 10:48 AM   #2
Capt. Mike's Avatar
I've never heard of a separate fuse for high beams and low beams. In my experience, there is one fuse for the headlight circuit, and everything works or it doesn't. It isn't likely that the high beam element is burned out on both headlights - one, maybe, but both? not likely. I think it would more likely be a bad headlight switch.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is online now   Reply With Quote
Old 12-22-2014, 11:22 AM   #3
TURBS's Avatar
Almost all newer vehicle have high and low beam relays as well as fuses that are seperate.
I know this is a motor home but may still a place
Apply.
Mike your truck has high and low beam fuses as well as relays.
Not to mention you also have seperate stop/turn and marker for the truck as well as the trailer.
Old 12-22-2014, 11:24 AM   #4
TURBS's Avatar
Ken Kaiser
Ken ...... is it possible that both high beam lights are out?
I've seen it before!
Also I would definitely remove your phone number from your post!
immediately if not sooner!
Old 12-22-2014, 12:04 PM   #5
Capt. Mike's Avatar
Apply.
I knew about the separate stop/turn circuits for the truck vs the trailer, but I had no idea about the high / low beams for the headlights. Is that because they got away from the old one-piece sealed beam lights?
Thanks, Ron. Guess this old dog learned something new today.
Mike and Yvonne
Old 12-22-2014, 03:07 PM   #6
Iggy's Avatar
Ken Kaiser
This is the way it is on my 2012 378TS
Fuse panel located under dash left side.
High Beam Fuse #35, 20 amp
Low Beam left Fuse #31, 10 amp
Low beam right Fuse #25, 10 amp
Iggy is online now   Reply With Quote
Old 12-23-2014, 10:08 AM   #7
Easy fix
Thanks for the picture of the fuse panel. I pulled the protective cover for the first time to discover the fuse in slot 35 was missing. Just for S & Grins I installed a 25 amp fuse [all I had] problem fixed the lights work as advertized. Seems someone failed to install a fuse. Easiest fix I accomplished in sometime.
Here again the FR Form saved me a trip to the dealer.
Thanks for the help.
Merry Christmas
Ken Kaiser
Old 12-23-2014, 10:59 AM   #8
Iggy's Avatar
Merry Christmas
Here are the two documents I use for Georgetown fuse panel under dash.
ID:	67782   Click image for larger version
Old 12-23-2014, 11:11 AM   #9
TURBS's Avatar
I think that the high amp demand for newer vehicle circuitry has forced them to fuse and or relay every single circuit.
We've long since went away from 30 amp alternators!
Volkswagen is putting on 200 + amp alternators!
light
