Old 12-05-2011, 04:36 PM   #1
No Hot Water
Washing dishes and hot water suddenly cut off. Opened pressure relief valve and tank is full. Any ideas. No hot water coming from any taps. Any ideas?
BWReg2011 is offline   Reply With Quote
Old 12-05-2011, 05:15 PM   #2
Boyd's Avatar
If cold water is coming out of your hot water taps, check the by pass on your hot water line. If NO water is coming out of your hot water taps, check for plugged or broken line.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 12-05-2011, 05:21 PM   #3
Just a thought. If you have a pull out faucet, perhaps the hose is pinched under the counter.
MikeA is offline   Reply With Quote
Old 12-05-2011, 05:32 PM   #4
I believe the poster is stating that water IS coming out of the HOT water faucet(s), but is not HOT. So--I would have to ask: Is this an electric water heater or gas fired water heater? One would have to know this before any troubleshooting could begin.
Thurman is offline   Reply With Quote
Old 12-05-2011, 07:27 PM   #5
Do you have Hot water at any of the other faucets, bathroom sink, shower, outside shower? Please list camper male and model, so we can help.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-06-2011, 11:00 AM   #6
HI
I'm also having problems with mine on 2011 378 unit. No hot water anywhere on propane or electric but water tank is full. Checked fuses and nothing blown, I do not even hear a spark igniter when using propane (propane tank is full). Pressed resetbuttons at heater. I have 2 switches, one at hot water heater should this be on? One on control panel with a rest light (no light (should this be on) is there a trouble shooting guide anyplace as I am very confused
Jim
Homejames is offline   Reply With Quote
Old 12-06-2011, 01:19 PM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
Suburban WH Tech Info.pdf
I believe you have a Suburban WH. Here's the info that should help you out. You may need to reset the water heater outside behing the rubber caps for both gas & electric. Hope this helps.
File Type: pdf Suburban Water Heater Service Manual.pdf (3.60 MB, 31 views)
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 12-07-2011, 06:43 AM   #8
Heater
HI
Thanks for this
Hot water is now working.
All I did was exercise the three valves for hot/cold & bypass and this fixed it, I think
All also did a few other things
bottom line I have hot water now on gas & electric
Jim
