Old 07-06-2011, 05:02 PM   #21
WOW! We experienced this as well last weekend. We cranked on the gen for the coach air and all was good till we stopped for gas. We turned off the gen, got gas, pulled around to park so DH could get us lunch and I flipped on the dash thingy for the radio to be on so you don't have to have the key on.
It got hot, I cranked on the gen and NUFFIN! NADA. GRRR. Never did figure it out till we got home and I remembered about the radio. I clicked it off, gen cranked up and A/C worked. I don't know if that's what the problem was for sure but that's the only thing I can think of.
Karen
Enjoying the great outdoors with one hubby and 2 boxers!
2011 Georgetown 280DS
2010 Jeep Wangler 4x4 Toad
KarenS144 is offline   Reply With Quote
Old 07-07-2011, 07:11 PM   #22
So you think it was the radio switch on the dash?? I just took mine to the RV dealer in which I bought it and they said it was a Generac issue and I had to take it to a dealer. I think they're taking the easy way out personally. Any other thoughts or ideas??
brianneal is offline   Reply With Quote
Old 07-07-2011, 07:12 PM   #23
Originally Posted by jd-ford-hd View Post
Would be nice to know what brand genset everyone posting here has. Mine is a Generac Guardian 6500. Lets see if this problem is brand related.
Same model for me.
Old 07-07-2011, 07:52 PM   #24
I haven't tried it since but I'll test it tomorrow if I get time. The radio switch is the only thing that changed. The A/C worked fine and we had power to the microwave when we first started the gen. Once it had been turned off and the radio switch on, we didn't get power to the A/C or the microwave when we started the gen again. I turned the switch off and then we got power to the A/C & wave.... Dunno!
I guess you could make sure the switch is off and see what happens.
Karen
Old 07-10-2011, 01:54 PM   #25
The procedure "Chasracer" outlined worked fine. I took my RV back to my dealer, they took the easy way out and said that they couldn't find the problem and that I needed to consult my local Generac dealer (100+ miles away). I emailed them the procedure here and when I picked up they said it worked. So.....kudos to "chasracer" for posting a solution. Thanks.
Old 07-22-2011, 10:26 PM   #26
dashonthedash's Avatar
I had no voltage output intermittently from my Generac until recently, when the "intermittent" problem became permanent. Dealer found a broken tab on the circuit breaker, but bypassing the breaker did not solve the problem. The local Generac dealer had a 3-week backup (says wonders for the brand, doesn't it), so my dealer sent the generator to another specialist, who found a loose circuit board connection. They fixed the connection and replaced the breaker, and the generator was producing voltage until it was replaced in the coach. As soon as the panel was closed, no voltage. When I last talked to the dealer, they were looking for a replacement circuit board, but they had no idea whether it would resolve the problem.
I frankly think that the generator is a piece of **** and have asked the dealer to quote me the cost of swapping it out for an Onan.
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 07-23-2011, 07:51 AM   #27
jd-ford-hd's Avatar
Back when I was pulling a 30' fifth wheel, I used a Generac 4500 portable on a hitch haul mounted on the rear of the trailer. Has given years of trouble free service and still is a dependable stand-by for the house. I was tickled to see a Generac in our new Georgetown. Now the tickle has turned in to an irritation..!
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 08-14-2011, 06:54 AM   #28
I just returned from a long trip up in Maine with our Georgetown. After going through the sequence (reset) suggested to me earlier, the gen worked fine. On the return trip (and when I needed the AC the most) the genset would start right up but produce no power. So, even though the 'factory reset' sequence I was tried before worked, it doesn't seem to be a long term solution. The closest Generac dealer is not so close, so I think I may need to tap my Good Sam Extended Warranty at this point. Very frustrating, Generac has been useless, my dealer has been useless and I can't seem to find a lasting solution. I'll let you know the outcome to this drama.
Old 08-15-2011, 06:33 AM   #29
ME
sparks1032's Avatar
I have the same genset as mentioned and had the problem all last year, until the switch for the radio went out (the one mentioned that plays radio when coach is off) and has not been fixed. Although difficult to believe this has anything to do with it but no problems this year.
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 08-15-2011, 07:56 AM   #30
I've been afraid to turn that radio switch on & try the genny. I don't know if that was our problem or not but don't want to screw anything up by testing it. We did run the gen & A/C last week on the way home but the radio switch was off. A/C worked fine!
Karen
