Old 08-20-2012, 04:00 PM   #1
no power to slides
Help, I have my slides out but can't get them to activate anymore, in or out. Had a problem with the jacks, but was able to reset the breaker and the jacks work again. When I push the slide buttons, nothing.
Georgetown 2007 359TS.
Hankster is offline   Reply With Quote
Old 08-20-2012, 04:10 PM   #2
TURBS's Avatar
Do u have power to the switch?
Power to slide motor?
Checked the fuses?
Old 08-20-2012, 04:39 PM   #3
armye7's Avatar
There is a 15 amp fuse under your steps that control your slide outs
armye7 is offline   Reply With Quote
Old 08-20-2012, 06:17 PM   #4
Tim & Lisa Trempert
Make sure your ignition switch is off. Jacks have to have the ignition on to work and slides are just the opposite.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-21-2012, 01:46 PM   #5
Thanks for the replies, will check for power and fuses. I have no internet at the campground and need to run into town to access it.
Ignition is off, slides are out, may need a 'wide load' sign to get home!
Hankster
Old 08-21-2012, 02:03 PM   #6
Had the same problem with our slides on 2007 Georgetown 340 this spring. After checking all fuses and circuit breaker three times, I was going to bring them in manually with a ratchet, while the hydraulic access was open, jiggled all the wiring to the motor and the slides came in and jacks worked, both were dead. I cleaned the connections and tighted better when we got home and everything is working fine since. there is a big relay in front of the motor with several connections, that is where I found the culprit. good luck.
akcampr is offline   Reply With Quote
Old 08-23-2012, 03:58 PM   #7
Thanks for the help. it was the fuse. under step, inside the panel, 15amp located in position F1. Slides are working again. Thanks again for the Georgetown forum.
Old 08-23-2012, 07:28 PM   #8
Iggy's Avatar
Can you use this diagram?
Website makes them smaller. If you want the full size version PM your email address.
John
2012 Georgetown XL - 378TS 63K + miles
