Old 04-10-2012, 09:50 PM   #1
Pete
gartonhl's Avatar
No power to steps-GT378TS..HELP!!!
Our steps have no "juice" to work them. I've checked the 5 amp fuse in the battery control unit under the coach entry steps. It showed good, but I went ahead a replaced it anyway. Still no work.
I checked the breakers and fuses in the bedroom panel. The diagram didn't show any fuse or breaker related to the step operation.
The step "rocker" switch located in the entry works and the step light under the steps works.
Does anyone have any idea what I'm missing? Is there a fuse possibly in the chassis fuse block under/by the steering column?
Any an all help is appreciated.
Thanks in advance,Pete
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 04-11-2012, 06:35 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
There's a fuse under the steps that are inside the coach. You have to take the steps out in order to reach the fuse. It's directly wired to the batteries. I believe it's in a dark blue fuse holder or it's dark green. I know it's one of those because I used a Silver Sharpie to write on the case "Steps". The other one goes to the LP Leak detector. If the steps are closed I'd place a magnet on the contact on the frame because when you replace the fuse they are going to open right into you legs.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-11-2012, 11:32 AM   #3
cfsoistman's Avatar
Georgetown-Battery Connect Center.pdf
This should show the fuse location at the control panel behind the steps.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-12-2012, 12:31 PM   #4
Pete
gartonhl's Avatar
Thanks cfsoistman.
Checked all the fuses you recommended. All good. I guess its probably the motor gone bad without blowing any fuses.
I'll probably get a new motor unless the bad one can be rebuilt.
Thanks again.
Pete and Patty
Old 04-12-2012, 04:08 PM   #5
HI ! PETE
Before deciding that the problem is the motor I would check out the
magnetic switch on the door, also in the step installation manual
there is a way of connecting the step directly to power which may help
determining if the problem is the control board or the motor.
Gary
mbtelguy is offline   Reply With Quote
378ts
