06-24-2017, 07:57 PM
No propane to range and hot water tank
I have a 2012 Georgetown 351ds while getting it ready for a trip i was checking out the range and the hot water tank,upon turning on the range and using the spark ignitor i had no gas coming thru the burner.The propane tank was full and valve open,same problem with hot water tank no gas coming thru.If anyone has any ideas why, or a remedy or fix i would be much obliged. Thanks in advanced.
06-24-2017, 08:06 PM
Are the stove and water heater on the same slide? Do they work when the slide is in and out? Assuming it worked before, it may be a kinked gas hose. Try manipulating the gas hose. I had this issue on my last MH.
06-24-2017, 09:07 PM
You might try turning the valve on the propane tank off, then turn it back on again slowly. The place I had the tank filled reccomended this. Not sure what it does but it worked.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
06-24-2017, 09:17 PM
Make sure your co and propane detector is working as it can control propane flow
switch
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
06-25-2017, 06:46 AM
I had a similar problem with my 2011 GT 300. It turned out to be the tank regulator was shot-- miss wired! Took it to a rv repair shop and a few hundred later I had gas to my hot water tank, range, and fridge.
06-25-2017, 09:34 AM
Yes regulator could be leaking test soap and water.
Don
06-25-2017, 09:43 AM
My regulator was hot to touch. The guy that replaced it said i was lucky. The previous owner hadn't done much camping and may not have ever used propane.
06-25-2017, 12:36 PM
As said first things I would do is turn off all gas appliances, turn off main shut off valve and then open slowly. Then check CO2 alarm, also inline fuse for alarm.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
06-25-2017, 12:43 PM
Probably a bad regulator. My regulator would go bad if I forget to turn off propane and purge the line when I have it parked for more than a month.
06-25-2017, 04:00 PM
It could also be that you just need to bleed the line. When you open the range burner can you feel a breeze, or if you put a lit match does the moving air move the flame. If so, be patient and see if it lights in a short while.
After that turn on the other appliances one at a time and bleed them as well.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
06-26-2017, 07:46 AM
Are you getting gas to your fridge ???
06-26-2017, 07:48 AM
BE VERY CAREFUL !!!
You do not want to turn your Georgetown in to a rocket !!!
06-26-2017, 09:36 AM
If you open the valve too quickly, it activates the safety shut off. Or something like that .
2017 Cedar Creek 34RL2
2014 Ford F-350
07-02-2017, 08:44 PM
Lottery Non-Winner
It could be that your batteries are dead or weak or a switch is off. Without enough DC, the valve won't open. Make sure you've got the switches in the configuration that allows your DC devices come alive.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
