Old 08-16-2015, 07:12 PM   #1
No water to toilet
Okay here's a weird one started our 3weeks got to our first campsite hooked up to water went to flush and no water, worked fine 2 weekends ago, any ideas, even tried tank water still no water. Have lots in tank and campground water, any ideas.
kdcamper 2014 Georgetown 377xl towing 2013 Toyota RAV4
kdcamper is offline   Reply With Quote
Old 08-16-2015, 07:15 PM   #2
Ford Idaho's Avatar
Construction debris in the flush valve.
Old 08-16-2015, 07:28 PM   #3
Sbryant's Avatar
Debris in flush valve - the flush valve can be removed by releasing the snap-in tabs and sliding it out toward the hose. Then disconnect the hose, look down in the hole where the hose went and then clean out the filter there. Mine was stopped up with fine white plastic shavings on our GT 360 XL
Sbryant is offline   Reply With Quote
Old 08-16-2015, 07:46 PM   #4
abjb's Avatar
Easy fix.
Turn the water off to your Georgetown.
Turn the sink or shower, hot and cold on to relieve the pressure.
Take the water hose off at the toilet, no tools needed.
There's a screen on the toilet, clean it with a paper towel and a toothpick.
There should be a lot of stuff.
Re-attach the hose, don't lose this thread IT WILL HAPPEN AGAIN.
MUCH more info here.
http://www.forestriverforums.com/for...ain-84612.html
and
http://www.forestriverforums.com/for...let-69645.html
ETC.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 08-16-2015, 07:52 PM   #5
Thanks I will look into that when I'm not so tired thanks for the help
Old 08-16-2015, 10:27 PM   #6
While you have the tools out, clean the filters on the kitchen and bath faucets. I do them once a year. Its suprising how much crud is in the FW system, even though we have a full flow filter on the water inlet.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 08-18-2015, 03:54 PM   #7
I had to do mine too on Saturday. Must be somethin' in the water.
As the others said, it was an easy fix.
DrewG is offline   Reply With Quote
Old 08-19-2015, 12:35 PM   #8
Arrived home from FL first of May....Parked 5er in DW until last Thursday....Left to go to a CG here in NS....After setup could not flush toilet...Got book out and called Dometic to verify problem and how to remove flush switch.....Took it apart and screen was plugged solid with hardened sand.....Washed it in a bucket of water and reinstalled...Still would not flush...Went to dealer and got a new one and I installed it for $60.00!!!!!.... Now works.....Will take old one home and blow it out with air gun and keep as a spare......Taps had no sand in screens???? Go figure that one out!!!! J
PS I do have a filter installed at 5er
Jim in Halifax is offline   Reply With Quote
water
