Old 08-23-2013, 09:02 PM   #11
n1joh's Avatar
my georgetown does to
I have a 2009 Georgetown 373 and my toilet did the same thing. I have to disconnect the line and clean the valve every time I went camping. I ended up installing a filter behind the bowl. and now no more trouble with it. the settlement come from the water heater rod from the bottom of the tank when you clean it after winter. when you close one valve and open another. now I just clean the filter and its all set.
n1joh is offline   Reply With Quote
Old 08-24-2013, 08:20 AM   #12
Success!! The fitting at the toilet was indeed clogged, amazing how much gunk I pulled out of it. It flushes great on the pump now.
Michael & Donna
Little Ones Karen & Becky
2012 Georgtown 350TS
2013 Wrangler Unlimited
Couple of Harley's (When not pulling the Jeep!)
Deland, Fl
Roadglider09 is offline   Reply With Quote
Old 08-24-2013, 10:33 PM   #13
Iggy's Avatar
You should always check the simple solutions first. Great you found the clog.
Old 10-10-2013, 05:37 AM   #14
Check your filter for sand and/or other substances it has plugged up my toilet and
Faucets several times. open the faucets and push down the toilet flush and run an air-hose through the water hose lines connected to the city water inlet it usually clears can the plugged lines also check the screens on the faucets as well
Allan007 is offline   Reply With Quote
Old 10-10-2013, 11:59 AM   #15
Iggy's Avatar
If you only read two messages above your it said it was a clogged screen at the valve of the toilet.
water
