Old 03-08-2013, 04:21 PM   #1
Now I Know
I left the Georgetown for the winter without putting boards under the wheels, I didnt think it would be this long without using it. You guessed it, one side is sunk down too far to just drive away. Any problem with lifting it up with the levelers to put a board under the wheels?
Ggantilla is offline   Reply With Quote
Old 03-08-2013, 04:52 PM   #2
Tim & Lisa Trempert
It can be done, but I'd be concerned that if the ground is that soft that the jacks will also sink in. I'd put boards under the jacks. Make sure you lift it evenly - all 4 jacks need to be on the ground. Good luck!
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 03-08-2013, 06:53 PM   #3
You could try putting a roof shingle on top of the board for some added traction.
Old 03-09-2013, 07:25 AM   #4
That's what I would do. Use a large surface under the jacks, lift the coach then put some boards under the wheels and drive off.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 03-09-2013, 07:37 AM   #5
acadianbob's Avatar
If you can't get the wheel all of the way out of the hole, you might have to try jamming some class 5 or something under the wheel. Or, put concrete blocks (or something of that nature) under your jacks along with the board.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-09-2013, 10:47 PM   #6
Thanks!
