07-03-2016, 04:53 AM
Now the KEY
Having the newbie Great Adventure with issues, problems and fun. But, last night after pulling into the RV park north of Valentine NE connecting to power and fresh water. The storage bay key on our brand new 2016 Georgetown 364 broke in half while using it. Of course we do not have the 2nd set of keys with us.?On the phone with CoachNet, nothing, Good Sam some help. Connecting up with a locksmith in Rapid City to make a new one. Seriously a key just broke, and fortunately we have money for a new key and more fun. Do you all have any suggestions? Is there some trick. It's crazy and we're headed to see CrazyHorse, George,Tom,Ab and Teddy. Happy Trails.
07-03-2016, 06:09 AM
You can buy extra keys on EBay. also get some graphite lube for the locks.
Daryl
2014 Georgetown 351ds
07-03-2016, 06:26 AM
Sky&Scuba
I think they want in now. If the key is broke in there you could take a small screwdriver and maybe get it wedge in the key hole next to the broken key and turn it.
I would not worry about damaging the lock most RV locks are very cheap to replace.
I change out all the doors and storage bin locks to take the same key.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
07-03-2016, 08:11 AM
I Break Everything
Exact same thing happened to us. The locks are stiff and the keys are junk. They should have given you two sets of keys.
Try these:
A. Stick the "half" key into the lock anyway, try to turn it to unlock.
B. Call the dealer, get the second set...DO IT!!
C. If one of the other compartments is unlocked, take off the lock - just a few screws, take it to a locksmith. Get a new key, only a couple of dollars.
D. Is any part of the key sticking out? Use needle nose pliers to pull it out.
Luckily when ours broke I was able to stick the remaining part of the key in and twist it to the unlocked position. I took off the lock, got out the key, went to a local locksmith had 5 durable keys made, done.
Good Luck!
2015 Georgetown Forest River 351DS Class A
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
07-03-2016, 08:22 AM
I believed they left the second set of keys at home. We always travel with two sets of keys for everything.
B and B
07-03-2016, 10:03 AM
Make sure you put some wd40 in keyhole regularly. Makes a big difference
07-03-2016, 10:22 AM
If you still have the head of the key it should have a number on it (all metal key). You can check with local RV stores and see if they have any spares. If it is the south co key with the black plastic head you may have to contact the company. The number is stamped on the metal shaft. Hope this helps.
2016 Georgetown 328ts
2015 Fiat 500 Toad
07-03-2016, 10:38 AM
We ordered a batch of something like 8 keys on Amazon for like 10 bucks.. They are all the same on MH's so it is a universal key.. Kind of scary but it happened to us so I put lube in the key holes.. In fact you could probably ask a neighbor with a gas motorhome to borrow their key but that wont help with the broken one
364 Georgetown 2016
in Montana
07-03-2016, 10:41 AM
Many RV use the same small selection of keys for the storage compartment. Check the head of the key for a number, Then ask other campers near by if they have that key. If you can get the broken piece out you may be able to borrow one. Sometimes you can tap rapidly on the lock and the vibration will make the broken piece move out enough to grab it with needle nose pliers.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-03-2016, 11:07 AM
The "741" key is probably the most used key in the RV industry. If you can get the old one out one of your neighbors should have one you can use.
I always use dry graphite to lube my locks. It doesn't get gummy or run.
Joel K
2013 Coachman Mirada 29DSSE
07-03-2016, 11:10 AM
Just change all the locks to match your main door key. Costs like $25 to change 5 locks to match.
2019.5 Rockwood 2509S
07-03-2016, 11:15 AM
CH751
07-03-2016, 11:58 AM
Originally Posted by Mr. Dan
CH751
Since the OP has a Georgetown, wouldn't he have the slam latch locks? If so, he would need the R001 key.
Bruce
07-03-2016, 12:44 PM
I had a key brake of in a storage compartment lock. I took it to a locksmith shop they were able to get it out and made a new key. We have the two sets that came with George plus a complete set that stays in the glove box of the toad.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
07-03-2016, 01:07 PM
Bruce
Mebbe... I was merely correcting a 741 post.
07-03-2016, 01:17 PM
Bruce
My Georgetown has both style locks.
2015 Fiat 500 Toad
07-03-2016, 04:18 PM
Locksmith should be able to cut key by code on the key.
Also be able to get broken part out as long as you Don't mangle it.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
07-03-2016, 06:03 PM
CH751
That's what I get for using my memory instead of walking 5 feet to look.
LOL
Joel K
07-07-2016, 06:37 AM
I wanted everyone to know that Harvey's Lock Smith in Rapid City is the best. A referral from Good Sam. We met them at their shop on a Sunday. We had both parts of the key so they were able to match the old key. I have 7 extras. Suggestions on where to hide them in case of another issue? Live and learn.
