06-24-2014, 06:48 PM
Oil changes
Where do you take your RV for its oil change? The nearest Ford dealer that can service anything my size is 40 miles away. Do you go to a big truck repair shop?
06-24-2014, 07:05 PM
Any auto repair shop should be able to do it but some won't. I take mine the same place I take my car.
06-24-2014, 07:14 PM
I do it myself, not hard at all, I only pay for the parts....
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-24-2014, 07:42 PM
You may want to check the terms of your warrenty if you do your own oil changes.If you are out of warrenty go for it
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
06-24-2014, 09:30 PM
Doin my own oil changes does not alter any warranty.... I worked at 2 dealers for 23 years, I know the game! Save your receipts for oil and filter purchases and document oil change intervals, keep all maintenance records!
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-25-2014, 01:00 PM
LOL. I've been doing my own oil changes for as longs as I can remember on new cars, motorcycles, etc. It's never voided a warranty. Now, if you are silly enough to leave the oil filter's gasket attached to the engine and install a new one on top of that....You will be paying for that one.
One of the best things I bought for my coach was a Fumoto valve. Flip it open, let it drain, close it and refill. For the filter, get it loose, put a Ziploc bag around it and remove it.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
06-25-2014, 01:10 PM
I did my last oil change since large truck ford service center is 20 miles away. For those doing your own oil change, do you lube chassis also?
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
06-25-2014, 01:21 PM
Yes. Will also be flushing the brake fluid at the two year mark. Apparently, some folk have had their lines leak and the warranty is voided if you can't show proof that the fluid was changed.
06-25-2014, 05:04 PM
Yes I also grease the chassis myself.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-25-2014, 06:59 PM
phat phrog stunt crew
If it has a zerk, it gets a shot of grease.
Sent from ny nook using fairly accurate digits.
06-26-2014, 01:17 AM
I do my own oil changes. You can buy the Ford filter and oil at Wal-Mart for about $30. A Fumoto valve (part # F-106N) is a huge help for changing the oil, as the drain is over the axle. The "N" version Fumoto valve has a nipple to attach a tube so the oil drains right into a bottle without spilling a drop. The Fumoto valves are available at Amazon.
A short flexible grease gun hose was necessary to access some of the grease fittings on the front axle. Turning the steering as far as possible to each side was also helpful. Autozone sells the Valvoline grease with molybdenum that meets Ford specifications.
I had Gator Ford in Tampa do the brake flush and refill. They are located next to Lazy Days RV, and probably service more Ford RV chassis than any other dealer. They had the proper machine to do the job. Cost was $150.
2010 Georgetown 373
2013 Jeep Wrangler
06-26-2014, 07:01 AM
Engineer of Crazy Train
X2 on getting a Fumoto valvle. Love them!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
07-03-2014, 11:09 AM
Happy Member
X3 on the fumoto valve
I also do my own oil change...pretty darn easy when you have the right tools.....Thanks to this Forum of course
Me, DW and final score...
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
07-08-2014, 09:15 PM
Don't forget there are nine (9) zerks. Don't forget the one on the steering box, there is a little rubber cap on it.
07-10-2014, 12:07 PM
Local Ford dealer does mine, including lube, for around $42. Doesn't seem worth it to do my own.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
07-10-2014, 05:38 PM
Oil changes
Might question what your getting for $42.00, are they using Motorcraft oil filter and oil ? Where I used to work- Ford dealer - they used valvoline filters and oil in the lube lane!
Plus for me, I know exactly what's been done and know that oil actually made it into the engine after an oil change! ( have seen it happen, tech forgets to put oil in vehicle and starts it up and attempts to move it out! Then it dies.... But I also understand that not everybody has the time, place or are able to do their own services.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
07-11-2014, 10:57 AM
I paid $52 for my last lube and oil change. Took it to the mechanic that does work on all my vehicles.
07-13-2014, 01:50 PM
New e450 v10 mh first oil change
WHEN IS IT RECOMMENDED TO DO THE 1ST OIL CHANGE? 2013 V10 E450
NOW AT 3800 MILES ??? GOING TO USE MOTORCRAFT 5W-20 SYNTHETIC BLEND AND MOTORCRAFT OIL FILTER. THE MANUAL I HAVE FOR IT DOES NOT SAY FOR THE V10, JUST THE 5.7.
KEVIN LANGSTON
07-26-2014, 08:34 AM
2013 GEORGETOWN 351 DS
Should have been done already. Our RVs fall under the severe use category. Also for the price of an oil change it is cheap insurance . If you use synthetic is much better for the engine, all of our vehicles have sny fluids in the engine , trans and differential.
GRV
We love to Roam
2013 Georgetown 351 DSF
2017 Honda Civic
07-26-2014, 08:46 AM
It is illegal to deny a warranty claim if you have done your own maintenance. But, you MUST keep a log, along with receipts showing purchase of the correct oils, etc. to thwart any mumbo jumbo a stealer would use to try and deny coverage. I loved the look on their faces when I rolled out the records, and then they had it in the shop for three weeks rebuilding the engine under WARRANTY.
