Old 02-05-2016, 06:47 AM   #11
Vince and Charlette's Avatar
There is a thread from last year where some insisted there are two water heaters on all 364s. However, earlier 2015 models had one water heater and 19.5" tires. What else I'm not sure.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 02-05-2016, 07:01 AM   #12
AquaMan's Avatar
I'm sure you are correct and glad they added the second WH as standard. I do remember seeing the 19.5" tires on some of the first ones out. The 2016's also have the 6 spd transmission, although a few of the first '16s were built on '15 chassis and have 5 spd. Do you have 2 water pumps? I also thought some more on your situation, if you had a frozen/cracked line, your city water would be spraying everywhere, so I don't think that is your issue. Check the clamps on the suction side of your pump(s). Also I don't remember seeing your answer, but you did make sure your tank was full correct?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-05-2016, 07:05 AM   #13
AquaMan's Avatar
Also, my sister lives in Spring Valley and is not that far from me. If you need any assistance when you get back, give me a shout and I maybe I can help you out.
Old 02-06-2016, 09:19 AM   #14
Thanks AquaMan. I plan to relook at everything today since I,ve got a little time.
2018 Berkshire 38A
pump, water, water pump
