Old 02-03-2016, 08:51 PM   #1
Vince and Charlette's Avatar
On the road - GT water pump on constantly
2015 GT 364TS - We've been on the road for two days traveling from OH to FL. We're using the fresh water tank as needed while driving. However, there is massive air and foam along with a little water at each faucet when its opened. Even the toilets are producing part water and part air when flushed. In addition, the electric water pump is running constantly. (Just de-winterized last week.) I'm guessing that the pump won't shut off because it's not sensing back pressure due to all the air. So, where could the air be coming from and is that what's causing the pump to run constantly? Anyone suggestions?
Of course, when we arrive at our destination in FL, we'll use city water, but want to get this resolved before heading back to OH in two weeks.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 02-03-2016, 09:06 PM   #2
Water pump
Could be valve that was opened to add antifreeze to system was not shut completely when it was dewinterized. Safe travels.
Donamac is offline   Reply With Quote
Old 02-03-2016, 09:57 PM   #3
toolman_57
Also, could be the filter screen cap next to the pump.
toolman_57 is offline   Reply With Quote
Old 02-04-2016, 07:07 AM   #4
Check and make sure your winterization valve is closed. It will be near the hose that sucks antifreeze from the bottle.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 02-04-2016, 07:43 AM   #5
All the above are Correct,your issue is on the Suction side of Pump! Do you just blowout with air or suck Anti-freeze also? It has been Cold in Spring Valley! Youroo!!
Old 02-04-2016, 11:07 AM   #6
DarrenK's Avatar
I had the same problem when I tried to use the pump the first time. The winterization valve was in the wrong position...easy fix for a change!
DarrenK is offline   Reply With Quote
Old 02-04-2016, 11:42 AM   #7
AquaMan's Avatar
You also didn't mention whether you filled the tank, or just added water to it. May have sucked the water out filling up the 2 water heaters (12gallons) plus the water lines. Also don't forget that the 364 has 2 water pumps so check both winterizing valves.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-04-2016, 01:47 PM   #8
May be some anti freeze in tank. Will cause foaming. l
Harkerr is offline   Reply With Quote
Old 02-04-2016, 09:50 PM   #9
Rechecked water valve and it appears in correct position perpendicular to the winteriser fluid hose. Hot water heater valves appear correct. Could be crack in pump or filter casing due to freezing although I did blow out the lines and also drew in two gallons of winterizer. (This is the standard version of the 364TS and comes with just one water heater.) Lools like I'll have to wait until I get back to OH to tear into it.
2018 Berkshire 38A
Old 02-05-2016, 03:57 AM   #10
AquaMan's Avatar
Not sure what you mean by standard version of 364, I thought the 364 came with 2 water pumps/heaters as standard, mine did. I also drew in about 4 gallons of antifreeze when I winterized, but I have a washer/dryer.
pump, water, water pump
