Originally Posted by Tbonz
Are both generator fuel filters the same? The one before the pump and the one after??
Yes, they're the same, but Onan now suggests replacing the one at the carb with a fitting,A026E529. They say dual filters aren't necessary. The newer ones only come with the filter at the pump.
I bought mine at RV Plus for about $20.
Also, do you have more than 1/4 tank of fuel? Genny won't run otherwise. You might also check for a pinched fuel line between the tank and filter. Not uncommon, either.
As for the missing cables to the RF switch box, it sounds like the previous owner may have done some changes, and then removed some stuff when he sold the RV.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
