06-23-2011, 09:18 PM
Onan Generator
Started the genset in mid to late April - no problems it took right off. Today I tried starting it again and nothing. I did the prime as per the manual but still nothing. This is in a 2010 Georgetown and has not been used except for following the instructions (i.e. starting and running monthly etc.) Any suggestions would be appreciated.
06-23-2011, 09:40 PM
Moderator
Well, you left some things out. If it is gas, you need at least 1/4 tank of fuel in the tank. If it is propane, did you urn the propane on? Since it is that new, doubt you have any wear problems, so you need fuel, and spark, should have compression. Check for fuel, and check for spark at the plugs.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
06-24-2011, 02:50 PM
Pete
Are your house batteries fully charged?
I think I'm right in this, but the generator needs the 12 volt house batteries to kick it of, so may sure they're fully charged.
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
06-30-2011, 06:34 PM
Had the same problem yesterday, after three tries I pulled the side cover off and turned the circuit breakers off, it started right up and ran fine, engaged the breakers and it ran fine. Shut it down after about 10 minutes of running and it restarted just fine. I did not have any electrical load engaged when it would not start. This is my 4th Onan and the first time this has ever happened. No clue why. Today it started fine, just checked while typing this post.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
06-30-2011, 09:56 PM
Thanks for everyones input. I turned the breakers off and back on again and great news it started. Let it run awhile and then put some load on and everything worked great. Stopped and started it again the next day and it took off no problem.
09-23-2011, 08:09 PM
Onan Generators
Make sure you run the generator often with a load. Also, put Stabil in the gas tank if your rig is going to sit for a while, make sure you run your generator to pull some of the treated gas into the carb. Heard the carbs are really bad about clogging up if you don't run them often.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 350 |
| 43 members and 307 guests |
| 64c10, armye7, BigDogD, biggie, cardinal4fun, DAISY BOYKIN, Dunefam, electrician549, elind, essness, fonzie, gljurczyk, greti, Hoo Dad, jaygeo1, jcoff2003, jdefeo1, JoeyO, kshocklee, ladyff1481, LFugate, Mad4sax, miatared, Namchief, Old car, Pa-cj5, patrapper, Pkdennis0504, railstar, rbrandon, Rest and Relax, Rickstermn, Russ, sail2liv, sandpiper, SinkorSwim, softwarejoe, spike, transamz9, Trevor43, T_LMurphy, UPGRADER, Vette4trcr |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
