Old 08-16-2016, 06:05 PM   #1
Onan Genset Gold
Stopped running and gave a fault code 36 that says pick up tube in tank too high. Pulled the gas pump from tank and the hose was bad. Replaced hose and ran great for months then the same problem and fault code. Pulled it apart again and found nothing wrong. Unit will start but will stall out like it isn't getting enough gas unless you hold the choke then it will run great. Is there something else that would cause this? It looks like there is some type of pressure switch in line with the new fuel filter.
Bill6890 is offline   Reply With Quote
