03-07-2018, 09:36 PM
One circuit is out. Can't find the breaker
So we are sitting here in our 31b3 and the TV dies. All outlets on one side of the rv are out. I reset all of the breakers at the end of the bed and no change. Any suggestions on what to do?0we are day 1 of basically our first camping trip with it.
2017 Georgetown GT3 31B3
N Little Rock AR
03-07-2018, 09:41 PM
Look for a GFI receptacle. Reset. Probably in the bathroom.
03-07-2018, 09:42 PM
X2 what cave said
Retired Navy
2016 Flagstaff 26 FKWS
03-07-2018, 09:46 PM
First place I went and it is good. The opposite side of the rv is having the issue.
N Little Rock AR
03-07-2018, 09:52 PM
Not familiar with your rig. I did learn that some have 3 GFI's. does your inverter have power?
03-07-2018, 09:53 PM
I don't have an inverter.
N Little Rock AR
03-07-2018, 10:10 PM
Do you have a 50 or 30 amp service?
30
N Little Rock AR
03-07-2018, 10:17 PM
Ok. Ruling out the split feeds of a 50 amp service means you have power inside if other 120v outlets work since a 30 amp service is a single 120v feed.
You mentioned finding one GFCI outlet, have you found any others? As mentioned there are usually two and sometimes three. One might be located in an outside compartment but not always.
03-07-2018, 10:20 PM
GFCI outlets feed and protect other (downstream) outlets. If you can't find any, you are going to have to start doing some electrical troubleshooting. Do you own a multimeter and know how to use it?
I checked the compartments. Found one outlet on the door side of the rv with a gfi label which looks like it is fed from my bathroom and is good.
N Little Rock AR
03-07-2018, 10:22 PM
Yes I have a multi meter.
N Little Rock AR
03-07-2018, 10:24 PM
Yes, outlets with a GFCI Protected label are fed from an upstream GFCI. Usually there is one in the bathroom and another in the kitchen but again, no two rigs are the same.
03-07-2018, 10:25 PM
I have found 6 outlets that are dead.... Primarily the TVs. None of them have the gfi sticker on them like the outlets on the opposite side.
N Little Rock AR
03-07-2018, 10:28 PM
Do you have a separate breaker in your breaker box for outlets other than those marked GFCI?
03-07-2018, 10:29 PM
Can you post a photo of your breakers and the labeling?
03-07-2018, 10:37 PM
Just as confused as you
Though I'm not familiar with your RV, check for a gfci at the kitchen sink counter. I have one at the end of my kitchen sink and one at the bathroom sink, even though they are on same side of the TT and within 5' of each other.
Richard & Jill
03-07-2018, 10:40 PM
Thanks all the suggestions folks...
N Little Rock AR
03-07-2018, 10:42 PM
The general breaker would have been my guess but it did not have an effect on my dead outlets...
N Little Rock AR
03-07-2018, 10:46 PM
Ok. You have a double pole, single space breaker for the outlets. One lever is for the GFCI outlets and the other is for the general outlets. If you have reset them both, are you comfortable removing the panel and checking for current coming out of the breaker with your meter?
