Old 04-07-2013, 07:37 PM   #1
One more question from a newbie on my 2013 352qs
There is a constant dripping leak from a hose behind my passenger side rear wheel. The storage compartment is marked low point drain. Is that normal and is that dripping supposed to be constant or do I have a leak? Please advise thanks.
Htab is offline   Reply With Quote
Old 04-07-2013, 07:42 PM   #2
Mountainmanbob's Avatar
you have a slight leak
there should never be any constant leaking anywhere
except from AC units
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-07-2013, 07:44 PM   #3
Professional Texan
TexasBob's Avatar
No it is not normal. It is used to drain your water system. Most have a valve or a cap on the end of the hose. Either the valve is leaking or the cap is leaking.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 04-07-2013, 11:16 PM   #4
Thanks guys. It looks like its leaking from the Hose I will have it checked out ASAP. Thanks for your help.
Old 04-08-2013, 07:52 PM   #5
Tim & Lisa Trempert
On mine, you just have to tighten the plastic plug that screws in the end of the drain hose. You can use a wrench if needed, but it's plastic so don't over tighten.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
