Old 06-19-2010, 06:13 AM   #11
mr.ken's Avatar
Thanks everyone. Turns out it was a quick fix. That clamp is all it was with no other damage. I won't get it back for a couple of weeks though since it's gonna go in for my punch out list. No way of knowing if that clamp just failed and fell off or was never there to begin with
2010 Georgetown 357qs
2009 chevy hhr
2007 chevy silverado
mr.ken is offline   Reply With Quote
Old 06-19-2010, 07:11 AM   #12
hi mr. ken,
when you get it back my sure to take some hose clamps with you.
hope you have many days of happy road trips.
bobby
2003chevy is offline   Reply With Quote
Old 06-21-2010, 10:28 AM   #13
Ouch, this one is going to be touchy. Depending on how much fluid you lost before shutting it down is going to give you some indication of how much damage your transmission suffered. I am not positive about the total number of quarts that trans holds, but it is a number that you will want to know. If you are anywhere close to 1/2 gone and the trans heat spiked up for any amount of time, its real easy to damage the seals and if it went on longer and got hotter, then the clutches/plates begin to slip, then burn. Unless it is just a few quarts, I would almost insist that they pull the pan and valve body to at least get an idea. With a cooler line completely off, you would be pumping fluid out at a rather impressive rate somewhere around 125 -150 psi. A number of years ago, I dumped about 4-5 from a 12 quart trans, fixed the leak and refilled it with ATF - thought I was okay until I burned up the trans the following weekend.
Chasracer is offline   Reply With Quote
Old 06-25-2010, 03:04 PM   #14
mr.ken's Avatar
I lost about 3 quarts and there doesn't seem to be any damage.
2009 chevy hhr
Old 06-25-2010, 05:01 PM   #15
kvtaylor's Avatar
Sorry to hear about your troubles Ken. Keep us posted. I'll check my lines before we go out again.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
