Old 12-20-2010, 12:29 PM   #1
Outside Bulb P/N
I need some info about my coach (2006 Georgetown). I left my coach in Florida for the winter and my parents are staying in it. They let me know that the outside light that turns on with the switch by the steps has burnt out. They are unable to read the part number on the bulb. Any one know the part number of the outside bulb? Thanks for the help.
capowers is offline   Reply With Quote
Old 12-20-2010, 02:31 PM   #2
If it has a metal bottom, with two small pins, one on each side,with a single filament, and you push down and turn to remove or install, it is an 1156. If it is all glass, with two small wires on the flattened bottom, and pushes down to install, and pull straight up to remove, it is a 921. either one can be found in the auto section of Wal Mart, or any auto parts store.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-06-2011, 02:40 PM   #3
#1003
phillip kent is offline   Reply With Quote
Old 01-06-2011, 04:41 PM   #4
Pete
gartonhl's Avatar
this is the one for a 2010 GT 378TS. #1003
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
bulb, georgetown
