Originally Posted by seacurt
thank you for the info. for the power part did you splice into something or wire to the fuse box? I understand the red and black and not the blue.
You could splice to any positive and neg as long as you can get the 12 volts. However, for me, I use the "mini fuse tap" to take the power directly from the fuse box located right below my steering column on the left side of the firewall.
By doing this, I could ensure that I am not "alter" any of the manufacturer wirings also I could have the separate fuse for the component too.
Note that when you tap on to the fuse box, you may want to use the probe to find the fuse that requires the key to turns the power on, this way your monitor would be on and off with your key.
Depend upon the size of your fuse box, it could use the full-size fuse or maybe the mini fuse. Make sure to use the fuse tap of the same size for your power as needed.
Here is the different size of fuse tap that you may use. You can buy these at your local auto parts store too, but it may cost you about $5 a piece. I bought it from amazon for couple bucks more, I have plenty to spare for my other project.
For the mini blades:
https://www.amazon.com/10-Pack-Add-c...words=fuse+tap
For the standard (full-size) blades:
https://www.amazon.com/Anfukon-Stand...+size+fuse+tap
As for the blue wire, you may skip that, just cut the exposed portion of the wire and use the electrical tape to protect the end from touching anything. This wire will not be needed because your coach already took care of your reverse signal.
Note that when it is working good, it will display your rear camera until you flip the turn signal to the left or right, then it will display your left or right video. Just like the manufacturer video signal.
Have fun.
