Old 11-12-2015, 04:35 PM   #1
rollin with the rudgies's Avatar
Outside speakers
I have a 2015 364TS. my outside speakers work great for playing the exterior TV and Radio. My problem is I cannot get the music that is being played via blue tooth thru the inside system to play thru the exterior speakers. I have tried the A, B and C settings on the inside player and get nothing. The Jensen on the exterior has no blue tooth option (even though there is a Jensen that does) but it does have a AUX setting. Does anyone know if this works if you plug a Ipod into the Auxillary jack inside the RV.
Any advice will be appreciated.
Thank you
rollin with the rudgies is offline   Reply With Quote
Old 11-13-2015, 01:14 PM   #2
mack1roc's Avatar
So you have a few options.
Yes the back of the Jensen has an aux option that you can by a cable for. However it's not iPod control friendly so you would have to control the music still through your iPod. Also if you have the exterior tv it's been a while since I looked but I am pretty sure the tv is using the aux input so you can play the tv through the outside speakers. So what I ended up doing instead of buying the new Jensen with Bluetooth was bought a cheap rf transmitter and play my iPod through the radio station I select on the outside speakers. Yes it is a hassle to find a clear station but it beats spending allot of money vs 15 dollars.
"MACK"
2006 F350 6.0 Diesel 3.73 4x4 FX4 "sold"
2010 Keystone Laredo 310RE 5th wheel "sold"
2015 Georgetown 351
mack1roc is offline   Reply With Quote
