Old 12-20-2014, 11:55 AM   #1
Outside TV Help
Hi, I have a 2014 351DS.
Can anyone tell me if the outside TV is connected to the front DVD player?
If so, how in the heck do you get it to work??
Preadus is offline   Reply With Quote
Old 12-20-2014, 04:13 PM   #2
I am not sure how it is wired but normally you have a junction box that allows chosing between off air and satellite. Do you see the coax for the antenna?
tycham is offline   Reply With Quote
Old 12-20-2014, 06:16 PM   #3
GABoy's Avatar
The DVD is not connected to outside TV. It's only to living area TV.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 12-20-2014, 06:44 PM   #4
Senior Member - Retired
The outside TV in our MH came with a dedicated DVD player, radio and boom box type speakers located adjacent to the TV.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 12-20-2014, 06:49 PM   #5
OK, I understand. You want to play a DVD and view it outside. You could get a distribution box that would allow and output it to the antenna. Doable but easier to just get a second player. I just got a second and it was $60 for a BluRay player.
Old 12-22-2014, 07:02 PM   #6
Thanks for the input. I decided to build a little shelf in the cargo are under the tv. I drilled a hole straight up and fed the power cable and hdmi cable up and into the TV box. It was a simple fix.
