Old 03-26-2014, 09:37 PM   #11
Iggy's Avatar
Originally Posted by wrapperman View Post
I have read that there is a connection on the roof for a satellite antenna but haven't noticed one up there.
The SAT cable is locate don the roof with also 12 volt hookup for SAR motor.
It is located ober tha passengers seat and looks like a vent on the roof.
If you were to install a permanent SAT dish on the roof you must remove that vent and you will find the coax and power wire.
Old 03-27-2014, 08:51 AM   #12
Yup, I couldn't figure out what that vent was so I removed the cap and there is a coax and 12vdc. I have one over the driver's seat and IIRC there is another one around the middle of the coach.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 03-27-2014, 02:47 PM   #13
VinceU's Avatar
I have the same issue with my 378. I can't find where that cable connection to the left of the door goes to. When I get my coach back later this weekend I will do a signal search and find out where it goes and post it. I just hook up cable to the back connection in the compartment top where the converter is located.
I am thinking it is for an outside TV hookup since there is a 110 v outlet
The switch in the upper cabinet has a position for cable, satellite and outside antenna.
Too bad Forrest River doesn't do a better job at documentation of components and accessories.
I did add a satellite antenna and a HD wireless transmitter to both TVs so I rarely use the R56 wires that are installed in the motorhome.
I saw a sketch furnished by FR awhile back showing all the coax runs for the 378. I had trouble with the outside hookup and traced all the wires to cure it. It turned out to be a bad TV. Meanwhile the cable conn in the basment is feed to an outside TV, it originates at a splitter for the front TV to rear TV then split again fo the outside outlet. I'm certain the first split is in the void behind the DVD cab. Remove the coax amp and AC outlet and pull up the multi cables, splitter is attached. Cannot recall where the bedroom/outside splitter is, but now you know it exists. With healthy TV set, it worked fine.
Check with Iggy, i believe he posted the sketch, a couple years ago. I received it with the new unit books but since have lost it. I remember, the provided splitters are not suitable for satellite signals.
