Old 05-23-2011, 08:41 AM   #1
Overhead light?
I have a 2007 Georgetown 350se. The overhead light right in front of the rear ac has stopped working. It appears it is wired into the ac unit. The ac and everything else works fine, except for this one light. I took it out of that location and moved it to another spot in the camper and it worked. Don't know what else to do.
Alabama-Fatboy is offline   Reply With Quote
Old 05-23-2011, 11:02 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
The AC is 120 volts and that light is 12 volts. The only 12 volts to the AC Unit is through the t-stat and I'm sure your lights are not wired into the t-stat. That light should turn on by a switch on the wall. There's also a switch on the fixture as well. If the switch is turned on at the wall then check to make sure someone didn't turn it off at the fixture. to the Forums
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-23-2011, 05:08 PM   #3
I have one in my closet that quit operating, as well. They are el cheapo plastic fixtures anyway, and most all trailer sales parts floors have them in stock. Randy
