Old 07-26-2015, 05:25 PM   #1
Overheating generator
Anyone have there generator overheating and shutting off? I am in florida and when it's above 90+ it runs for about 20 minutes and then shuts off. My 378 is a 2012 and has never done this before??????
daddio is offline   Reply With Quote
Old 07-26-2015, 07:38 PM   #2
abjb's Avatar
Ours has, I had the altitude set for over 7k which is where we usually are. We were at about 1k and over 100.
You also might to check your oil and air filter.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-26-2015, 07:53 PM   #3
Tim & Lisa Trempert
Also check the rubber shroud around the air filter and make sure the front is on tightly. Any air leaks in the housing will cause it to overheat. Also can be caused if your exhaust is getting clogged. Have you pulled the plug on the muffler recently so the residue in the exhaust can be expelled?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-26-2015, 08:06 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
When the last time you changed the air filter? Later RRJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-26-2015, 08:08 PM   #5
Tim & Lisa Trempert
More likely a dirty fuel filter than air filter as a dirty air filter will cause a richer mixture.
Tim & Lisa
2011 Georgetown 350
Old 07-26-2015, 08:18 PM   #6
Great thanks I will change air filter and check for leaks.
Old 07-26-2015, 08:50 PM   #7
Yes I will change fuel filter too. Thanks. Trempert!
Old 07-27-2015, 08:34 PM   #8
actually, it's most likely the fuel pump....
it's a simple fix, you can do it yourself. starting, running for 15-20 mins, and then shutting down is a classic sign of a dying fuel pump.
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 07-28-2015, 06:15 AM   #9
Great thanks,
generator, heating
