Old 02-25-2012, 09:50 AM   #11
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by polkatronron View Post
With clearcoat wax is not required...all it does is collect dust
Ditto!
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 02-25-2012, 11:33 AM   #12
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by barlin44 View Post
Hey Charlie,
So which Mothers product do you use, due to the ease of use and no streaking. The regular or the synthetic or?
Thanks and Happy motoring
I use the California Gold Carnauba Cleaner Wax- Safe for Clearcotas & Removes Oxidation & Restores Color- Safe for All Paints
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-25-2012, 01:11 PM   #13
nemo45's Avatar
Well, it can't restore color on a vehicle with clear coat because you are not getting thru the clear coat to the base color. I doubt if you'd have much oxidation with the clear coat either. Why waste your time?
Old 02-25-2012, 03:35 PM   #14
barlin44's Avatar
Thanks Charlie for the reply,
Keeping any paint waxed and or sealed will keep particles from settling into the coat of paint, which over a period of probaly years will provide payback while still looking new, "and it sure looks shiney right after waxing". You can tell those that have been negleted theirs over the years.
Besides its good exercice to wax on wax off.
Thanks Barney
Life is nothing but a dream,
We only go around once, so never miss a chance to smile.
Barney
barlin44 is offline   Reply With Quote
Old 02-26-2012, 06:50 AM   #15
I have always waxed once a year even with clearcoat. I believe after a season of travel there are micro scratches in the surface coat. A little additional protection doesn't harm anything. Mothers is my product of choice.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 02-26-2012, 09:38 AM   #16
cfsoistman's Avatar
No kidding! I just typed what was printed on the bottle. The product is made for numerous applications. I rather waste my time protecting my investment than just finding something to pick apart when information is being shared. We're here to help each other not see how many posts we can get by just being negative.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-26-2012, 11:19 AM   #17
nemo45's Avatar
I wasn't picking apart your info. Just adding my opinion. Yes, it would say on the label that it would restore the color, the are lots of vehicles out there without clearcoat. Also being safe for clearcoat doesn't mean it is needed. Muther's waxes are great products and if I was going to wax myself that's probably what I'd use. What I was trying to say was with two coats of clearcoat you don't need to. Now, having said that, when we are down here in the valley (Rio Grande) we get our motor home washed and waxed mainly because we can ge it done for $70. We have it done twice in the 5 mos. we are here, when we get here and just before we leave. While we are back home we wash it twice also, when we get there and just before we leave. We don't wax it ourselves. And when you stop and think about it, really, how much more is a clear coated vehicle going to be worth in 5 or 6 years because you waxed it? But, heh, that's just old lazy me. Still, I'm not dissing your info. It's good information and so is mine. I was trying to help the lazy ones like me.
Old 02-29-2012, 07:29 PM   #18
“Clear coat” is a name given to the multi-stage paints used today. A “base coat” is applied with a pigment (color). Then, a top layer of clear paint is applied over the top of the base coat to add depth, brilliance and provide protection for the base coat.
Clear coats still require the same care as the old single-stage paints. Just because the top coat of paint has no pigment in it doesn’t make it impervious to environmental conditions. Top coats of clear paint still oxidize, and the softer paints used today also allow contaminants to easily embed in the surface. These softer paints require modern formulations and technology to protect them against damage.
In short, the need for proper care and maintenance of clearcoat paints is just as important as years ago. Actually, because of their softer, fragile nature, they really should be maintained better than the older single-stage paints.
louis cherry is offline   Reply With Quote
Old 03-02-2012, 11:27 AM   #19
nemo45's Avatar
Not quite, they do put UV inhibitors in the clear coat. While the clear coat may oxidize some, certainly the base coat is not going to oxidize and you are not going to get to it with the wax anyhow. As proof, no color on the rag when applying the wax or buffing as you used to get when you waxed non clear coated paint. The clear coat is softer but that is so it doesn't scratch as easy. When a wax label says "safe for clear coat" that means there is not abrassive material in the wax so as not to scratch it, as there might be with say a rubbing compound. Anyway I bow to the Sensi, wax on, wax off. Only its not going to be me doing it. Not for $70 twice a year.
Old 03-04-2012, 09:21 AM   #20
JimF's Avatar
On my 2011 378 I received a booklet from the paint company that gave instruction on maintaining the paint, how to clean it and what to use for wax as well as the instruction on frequency of waxing (clearcoat does require wax). I would suggest you read the manual.
JimF is offline   Reply With Quote
