07-22-2017, 03:56 PM
#21
Originally Posted by msalyer
Could be the connection doesn't work at the pedestal.
Good thought, if we go directly to a TV set it works.
07-22-2017, 03:59 PM
#22
Wow. I'm out of ideas.
07-22-2017, 04:37 PM
#23
In the picture of your switch box you got it set on sattillite not cable look at the picture.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
07-22-2017, 04:39 PM
#24
Don
Don we have tried all three TV/cable/satellite. Still nothing. That is just where I ended up. Just tried again there were 135 RF channels found and that was it!
07-22-2017, 04:44 PM
#25
The switch box could be bad. I would use a double female connection and hook the cable coax going in the back of the box and the cable to tv together to test.
07-22-2017, 04:46 PM
#26
It could be however it went bad between the last park and this one, however I guess things have to fail at some point right.
#27
Is there some other georgetowner by you can try there switch box, maybe a
issue with yours. I carry an old one from our old MH had push buttons.
Don
07-22-2017, 04:53 PM
#28
We are using regular coax cable is there anything different for a digital signal?
07-22-2017, 04:56 PM
#29
Have you got a cable coupler join the cable to switch and join to tvout and see
if you have channels.??
I think that what I mean
Don ?
07-22-2017, 04:57 PM
#30
We are trying a direct connection to the outside tv to eliminate the cable and the park post.
07-22-2017, 04:58 PM
#31
Park Cable in 2016 364TS
Directly connected to the park post using same cable as we used to connection in cargo pod and we have found channels. So that eliminates the parks service as an issue and our hookup coax cable as an issue.
07-22-2017, 05:05 PM
#32
Don
Sadly the people at the park here this year are not particularly friendly as the people that have been here in prior years. We are a couple weeks later in our arrival. No other Georgetown or forest river folk here now there was a wild Maxx trailer here earlier (they are forest river) but they have left now.
07-23-2017, 05:24 AM
#33
World Wide Wanderer
It has to do with the quality of the splitter installed in your RV. I don't know what the difference is but it has to do with the Ohm rating and impedence. You need a "better" grade of splitter. Hopefully someone with a better electronics background than mine can tell you what you need.
Aaron[emoji41]
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
07-23-2017, 06:05 AM
#34
Digital TV signals have a higher frequency. Make sure that you have R6 coax cable. More importantly, make sure any splitters in the system are rated for digital signals. When local cable company at home upgraded to digital, I had to go through the house and replace all of the splitters that I had installed over the years.
Sent from my XT1254 using Forest River Forums mobile app
Bill & Beth
Hyde Park, NY
2014 Sportscoach Cross Country 405FK
2015 GMC Acadia
07-23-2017, 10:14 AM
#35
Try scanning with your tv on OTA/antenna instead of cable
Randy (& Elaine) Corbin
07-23-2017, 10:23 AM
#36
I think afd51 is correct I believe it is the splitters. Anyone know where they are all located in the 364 TS?
07-23-2017, 03:20 PM
#37
Here's a shot in the dark
What brand of tvs do you have?
In Our 2014 George XL we had Furrions in two areas and a Seiki in the bedroom
At a few campgrounds and Fort Wilderness at Disney the Furrion were good but unable to to get any channels on the Seiki in the bedroom. Problem was the signal and the type of tuner used in the Seiki their tuner unable to pick up signal.
Researched on Google and cited type of tuner in Seiki. Told dealership but would not listen- said impossible they instead swapped out tv 2 times charging Forest River under warranty. Shame on them. Forest River swapped out a 3rd time with a Furrion. So this is the 4th tv in that area Have not had a chance to test but don t expect problems
If you plug directly into tv you will determine either the tv tuner can t handle the signal from camp ground up grade or your problem lies else where
Tuner and upgraded signal system is my guess
07-23-2017, 04:14 PM
#38
As previously posted tv's work fine if directly connected to park pedestal so must be in the switch block or the splitter. It is only this
One park we are having trouble with due to the digital signal. Not experiencing issues at any of the others we stay at.
07-29-2017, 11:34 AM
#39
Bypass the box and get the cable to run directly to the TV. Take the input to the box and hook it to TV. Make sure Tv is set to cable input.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
